dijit.form.FilteringSelect with SQL database
889
08-12-2010 05:29 AM
KeithSandell
Does anyone know if it is possible to and/or how to go about wiring up a sql database to a FilteringSelect widget?
I have a database table with about 1500 rows and I would like to wire up two(2) FilteringSelect widgets to create a definition query against two (2) columns, but obviously it would be crazy to move all that into a json or other format.
Thanks.
derekswingley1
JavaScript isn't going to be able to talk to your SQL DB directly. You'll need to use something server side to make the connection, run a query and serve out the results.
