Difference in area calculation geometryService vs ST_AREA
1080
07-05-2017 01:58 AM
ArjanLuchies
Hi all, I keep getting small differences in calculating the area of a feature. Using the geometryservice (with a geometry from FeatureService) from the esri API (3.17), the result of an area calculation differs slightly from running ST_AREA(SHAPE) directly on my Oracle database. Parameters used (spatial reference, polygons etc.) are all the same. Any ideas what could be causing this?
Tags (1)
DanPatterson_Retired
Do you have an example? Do both actually do a calculation with the same numeric representation?
