Delete Cluster Layers
1304
08-07-2024 11:06 PM
LIZDean
I have some Javascript code that creates three cluster layers.
I need to be able to clear the three layers (workLayer, educationLayer, volunteerLayer) when I start a new process but can't figure out the right function.
This is what I have but it leaves the layers / graphics there.
 function clearLayers() {
                [workLayer, educationLayer, volunteerLayer].forEach(layer => {
                    if (layer.source) {
                        layer.source.remove()
Sage_Wall
Hi @LIZDean
  • FeatureLayer.applyEdits() - if you want to delete the features but leave the layers for later use
  • Map.removeMany() - if you want to remove the layer from the map but maybe readd it again
  • FeatureLayer.destroy() - if you want to destroy the reference to the layer and free up the memory. The layer and any associated resources no longer exist.
LIZDean
Thanks @Sage_Wall I will give them a go 🙂
