Getting attribute information for deletedFeature
1709
08-06-2024 03:44 AM
Aeseir
We have a feature layer that is created client side e.g.
const featureLayer = new FeatureLayer({
      title: "Test",
      geometryType: "polygon",
      objectIdField: "ObjectID",
      fields: [
          alias: "ObjectID",
          type: "oid"
          alias: "id",
          type: "guid"
          alias: "Type",
          type: "string"
          alias: "identifiedMarkerID",
          type: "string"
          alias: "recordedDate",
          type: "date"
      source: [],
      spatialReference: view.spatialReference
we then listen to the featurelayer event "edits" and key changes get pushed to server.
problem is that deletedFeatures doesn't show attributes of the said deleted feature, only objectId and globalId, there is no way to access attributes to get the identifiedMarkerID.
we need to be able to record that a feature with identifiedMarkerID that was deleted so if we get audited, we can see that feature was removed and when.
we use the editor widget to handle all the client side feature addition/modification/removal.
Any advice on how to do this.
JoelBennett
MVP Regular Contributor
There doesn't seem to be a "natural" way to do this since by the time "edits" has been fired, the feature has been deleted, with no way to get its info from the layer anymore.  The widget otherwise provides nothing like a "before-edits" event, which would be helpful in this regard.  I see a couple options here though.
First, you could put logic between the "edits" event and your changes getting pushed to the server.  In this intermediate step, you could get the feature's data from the server before sending the information to the server about the feature being deleted.  This kind of workflow would require an extra server request being added to your overall workflow, and so would be somewhat inefficient, since you'd be sending a network request to get information that existed on your client less than a second ago.
The other option is to add a hack that gets you a reference to the feature before it gets deleted.  The best way appears to be by overriding the deleteFeatureFromWorkflow method of the Editor widget, because this method gets called immediately after the final "Delete" button on the widget is clicked, but before the delete operation actually takes place.  Therefore, this would be the ideal place to examine the attributes of any features being deleted:
var editor = new Editor({view:view});
var deleteFeatureFromWorkflow = editor.deleteFeatureFromWorkflow;
editor.deleteFeatureFromWorkflow = function() {
	//This is the array of graphics being deleted
	var graphics = editor.activeWorkflow.data.candidates;
	graphics.forEach(function(graphic) {
		//Do something with the graphic reference here
		console.log("identifiedMarkerID: " + graphic.attributes.identifiedMarkerID;
	return deleteFeatureFromWorkflow.apply(this, arguments);
JoelBennett
Aeseir
I like it, i hacked a different approach but yours essentially creates a lifecycle hook.
JoelBennett
Nice, good to hear you got it working.  The description of the arguments object here is definitely better than what I would come up with.  By calling apply with the arguments object, it ensures the function being called is executed with the same arguments (if any) that were passed to the current function.
Aeseir
Yep sorry i removed my query about arguments, brain wasn't fully operating when I finally got it to work.
