Dateformat on infowindow
4865
14
01-26-2018 05:07 AM
EvelynHernandez
Hello, I have the following question.
How can i set up a dateformat for a infowindow? Right now my problem is the infowindow is showing a incorrect timezone, (-3 hr to my current timezone), so i need to fix it.
Here is my code:
let chInfoTemp= new InfoTemplate();
 chInfoTemp.setTitle("<b>Current:</b>");
 let chInfoContent =
 "<div style=padding-top: 10px;><b>Starting: </b> ${initial_date:DateFormat(datePattern:'d MMMM yyyy, HH:mm:ss.', selector:'date')}<br></div>"+
 "<div style=padding-top: 10px;><b>Final:</b> ${er:DateFormat(datePattern:'d MMMM yyyy, HH:mm:ss.', selector:'date')}<br></div>";
 chInfoTemp.setContent(chInfoContent);
Thanks in advice!
RobertScheitlin__GISP
Evelyn,
  There is a setting in ArcGIS Server manger that will help for this:
EvelynHernandez
Oh im going to try that, thanks
EvelynHernandez
Oh wait, mine doesnt have that option!
Evelyn,
   Then you are running an older ArcGIS Server.
EvelynHernandez
So there is another option to do that?
EvelynHernandez
Thanks im going to look at it
DavidColey
MVP Frequent Contributor
Hi Evelyn, here's something we used back at 3.14:
convertDate = function (jsDate){
       //console.log(jsDate);
       var myDate = locale.format(new Date(Math.abs(jsDate + 14400000)),{
             selector: "date",
             datePattern: 'MMMM d, yyyy'
      //console.log(Math.abs(jsDate + 14400000));
       return myDate;
Then in my popup template description I'd just set the function:
var popup = new PopupTemplate({
       title: "My Title",
       description: "<b>Account:</b> {ACCOUNT}" +
          "<br><b>Date:</b> {SomeDate:converDate}"
The constant value you see is for EST, so you'll have to play with that to get your time zone.
EvelynHernandez
14400000 is 4 hrs?
Im right now in gmt -3 , and another thing i want to ask you is u are using dojo.locale, right?
Right now im not using popuptemplate, im using infotemplate, so the code that  i have is the following.
var convertDate = (jsDate) =>{
 var myDate = locale.format(new Date(Math.abs(jsDate + 108000000)),{
 selector: "date",
 datePattern: 'd/MMMM/yyyy HH:MM:SS'
 return myDate;
let chqInfoContent =
 "<div style=padding-top: 10px;><b>Time  </b> ${initialDate:convertDate}<br></div>"+
 "<div style=padding-top: 10px;><b>ETR:</b> ${ETR:convertDate}<br></div>";
And the resolution that i have is showing me the infoWindowin milliseconds.
Thanks for ur help!!
