Datagrid onMouseOver and onMouseOut
5238
14
08-27-2014 06:28 AM
MayJeff
I try to write a function for mouse over and mouse out datagrid.  Here is JSFiddle:
Edit fiddle - JSFiddle
Please help me to take a look what I need to change.
Thank you.
RiyasDeen
Hi Ken,
Thanks for highlighting that. Since i was zooming in on mouse over (which is what click does), click event seems to be doing nothing.
Below Update.
Jeff,
Since map.graphics always sits on top, i have moved your search results to selectionLayer and highligths to map.graphics, in the above fiddle.
KenBuja
MVP Esteemed Contributor
You have a couple of errors in your code. First, when using the "dojo/on" events, the event are usually in all lower case without the "on" prefix. Use the "mouseover" event.
grid.on("mouseover", onMouseOverHandler);
Second, you're initializing a new local variable "grid" in the "showResults" function
var grid = registry.byId("grid");
but you also have a global variable "grid", which you're trying to access in the "onMouseOverHandler" function. The global variable is never set to anything since you used a local variable. It should be like this
You haven't defined "selectionLayer" anywhere.
RiyasDeen
Hi Jeff,
I have removed on from your line 127 and 128.
  grid.on("MouseOver", onMouseOverHandler);
  grid.on("MouseOut", onMouseOutHandler);
Is this what you are after?
MayJeff
Thank you for your JSFiddle.  How do I change the graphic symbol to sfs that I defined at the beginning of the code?
So  when mouse over the datagrid, will highlight the polygon.
Thank you.
MayJeff
I found this old link for Highlighting a graphic when the user hovers over a row
Synchronizing map and data grid interaction with the ArcGIS API for JavaScript | ArcGIS Blog
RiyasDeen
Hi Jeff,
I have updated the fiddle to highlight on mouse over and out. I have changed your symbol color and style.
KenBuja
However, it no longer highlights the parcel when you click on the extreme left column in a row.
RiyasDeen
Hi Ken,
Below Update.
Jeff,
RobertScheitlin__GISP
Riyas,
  I am curious. Why not just set the symbol of the existing graphic instead of adding a new one, and then set it back on mouse out?
        function onMouseOverHandler(evt){
          if(evt.rowIndex == -1){
            return;
          var rowId = grid.getItem(evt.rowIndex).PARCELID;
          //Loop through the graphics until you find the graphic with the ObjectID that matches
          //the selected row.
          arrayUtils.some(map.graphics.graphics,function(graphic){
            if ((graphic.attributes) && graphic.attributes.PARCELID === rowId) {
              graphic.setSymbol(sfs);
              return true;
        function onMouseOutHandler(evt){
            if (graphic.symbol == sfs) {
              graphic.setSymbol(symbol);
              return true;
Edit:
I am just asking for my own sake, if just setting the existing graphics symbol would not be more optimized than adding a new graphic over the existing one?
RiyasDeen
Hi Robert,
Your's is the better way of doing it. Frankly din't occur to me then
