customize layer labels
6103
15
01-16-2017 09:48 AM
EvonFranklin
How do i customize layer labels from a MapImageLayer? current layer code below
 var resultsLabelLayer = new MapImageLayer({
                  url: url,
                   sublayers: [{
                                labelsVisible: true,
                                visible: true,
                                labelingInfo: [{
                                              labelExpression: "[CONST]",
                                              labelPlacement: "always-horizontal",
                                              symbol: new TextSymbol({
                                                color: [ 255,255,255,1 ],
                                                font: {
                                                  weight: "bolder"
map.add(resultsLabelLayer);
Using this and adding the layer to the map yields no labels or the layer being drawn
EvonFranklin
True worth a try, I will look into turning this on.
EvonFranklin
Turns out that does the trick, after consulting the manager and enabling this feature. Thanks for your advice I would not have picked that up from the examples myself.
MichaelVolz
Esteemed Contributor
It would be nice if the sample told you that this was a required setting for your service to work.
MichaelVolz
When did the MapImageLayer object become available in the JS API (version)?
EvonFranklin
Since 4.2 I assume
Phaelipticus2
Guys,
I´m using 4.15 version.
I´m trying to show the server-side labels on the view but only works with FeatureLayer. But I need to show sublayers on the menu widget, that´s why I have to use MapImageLayer.
There is no problem with my code because I can see the layer in the view. Supported Dynamic Layers = true and put ID on MapImageLayer as well. Checked hundreds of times. I tried what you guys said.
Anyone have a clue? Is that the 4.15 version to old for MapImageLayer?
Can anyone help? Thanks!
