CustomContent with Popup
1542
07-11-2023 11:34 AM
BhavinSanghani
I am trying to display custom content in this sample https://codepen.io/b2810s/pen/WNYrveg but it doesn't display or call the creator().
It looks like a bug with the API. Is there any alternative to display custom content on popup without adding graphic or feature layer?
I want to display popup with the routes near to the clickpoint. Routes will need be displayed with they hyperlink so, user can click on it and open the route details.
JohnGrayson
Esri Alum
The 'content' property of the 'openPopup()' method doesn't list CustomContent as valid parameter type.  For your use case you can just use a function that returns the HTMLElement directly:
https://codepen.io/john-grayson/pen/BaGJMvw
JohnGrayson
Esri Alum
BhavinSanghani
Thanks @JohnGrayson , that worked for me!
