Solved! Go to Solution.
Hi there,
Thanks for the clarification! I should’ve read the post a bit more carefully.
You're almost there! BaseTileLayer and WebTileLayer are preconfigured to use the Web Mercator spatial reference. To align your BaseTileLayer with your service, you'll need to explicitly set the tileInfo, spatialReference, and fullExtent properties in the custom layer's constructor.
This CodePen demonstrates that approach: https://codepen.io/U_B_U/pen/yyyBzMO?editors=1000
Alternatively, if you want to avoid creating a custom layer, you can use WebTileLayer directly as shown below:
const tiledLayer = new WebTileLayer({
urlTemplate: "https://services1.arcgisonline.co.nz/arcgis/rest/services/Imagery/newzealand/MapServer/tile/{z}/{y}/{x}",
tileInfo,
fullExtent,
spatialReference
Hi there,
I believe you're talking about projecting your TileLayer into different spatial references. Please let me know if I’ve misunderstood.
It's important to note that TileLayer cannot be reprojected on the client side. This is outlined in MapView.spatialReference doc, specifically, it states that in order for
TileLayer and VectorTileLayer to render correctly as part of a basemap, the MapView's spatialReference must match the tileInfo.spatialReference of those layers.
Hi there,
tileInfo,
fullExtent,
spatialReference
Thanks for the replies Undral.
I'm happy to accept this post as the solution, but it would be great if either:
- this could be added to the Documentation for the BaseTileLayer
or
- the BaseTileLayer could interpret this information from the server specified, as it does in TileLayer.
Speaking to whether this should be a feature of BaseTileLayer: While I have solved my issue, in order to handle different basemaps I need to query and digest the content of the mapServerResponse, which I feel like should be handled by the BaseTileLayer class.
Speaking to whether this should be documented: In the integration I am doing I had gotten to the TileInfo and SpatialReference addition, but that was through stabbing in the dark and getting lucky. I was just missing using the constructor for creating the TileInfo and specifying the lod's. After adding the tileInfo, spatialReference and fullExtent to the constructor, it seems to be working for all spatialReferences without issue.
If: "To align your BaseTileLayer with your service, you'll need to explicitly set the tileInfo, spatialReference, and fullExtent properties in the custom layer's constructor." was specified in the BaseTileLayer documentation, I am sure I would have found it a lot easier to get this working.
Thanks again for your time and assistance in solving this issue.
Cheers,
Greg.
Hi there,
BaseTileLayer is designed to be a generic tile layer and is not limited to working with ArcGIS map services — that's what TileLayer is for. Because of this, it doesn’t make assumptions about the type of data it can retrieve from various sources.
Could you share a bit more about why you're creating a custom BaseTileLayer? Understanding your use case will help us improve support and documentation.
We'll update the BaseTileLayer documentation to reflect this workflow more clearly.
Okay, that makes sense.
Thanks for actioning the documentation change, I think in light of the use case outlined that would be a welcome addition to the documentation.
We are using BaseTileLayer to cater for Offline and Hybrid Online/Offline basemaps, allowing us to take Basemaps offline for use without internet on a device.
The main value it provides for us is the ability to override fetchTile, which we can then point to our local database, and failing that back out to the TileLayer URL.
We create three different definitions for a TileLayer.
- An OnlineTileLayer, which calls the unextended fetchTile
- An OfflineTileLayer, which makes a call to the devices database, to check if there is a tile at the specified row, col and level, and display it if there is.
- A HybridTileLayer, which makes an offline call and either uses that value on success, or on failure it makes an online call, which it will then optionally save to the database for later offline display.
Hi there,
The BaseTileLayer overview doc will be updated with the following info in version 4.33.
