Custimizing Popup Widget Template
2265
01-25-2019 12:49 AM
Den-GIS
I'm trying to set the "Layer List" button on the popup widget open as the default setting.The goal is when the user clicks on the map it should immediately display the identifiable layers.
Is there any possibility to get such setting?
Thanks in advance
RobertScheitlin__GISP
Denis,
   There is no why to set the menu to be open by default for the popup. When you programatically open the popup using the open method then you can set the property called featureMenuOpen to true.
Here is a workaround though that works:
watchUtils.when(view.popup, "selectedFeature", function(evt){
  setTimeout(function(){
    var menu = query(".esri-popup__feature-menu-button")[0];
    menu.click();
  }, 300);
Denis,
    menu.click();
  }, 300);
Den-GIS
Robert,
I've also seen the open method and property featureMenuOpen. I've tried something with it, unfortunately It didn't work  I'm not in the Office right now. I will try to integrate your Code. I'll give you a Feedback as soon as I've tested. greetings
Den-GIS
Robert,
I added your code, unfortunately it did not work. Here is my entire code example.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Custom popup</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/MapImageLayer",
"esri/layers/FeatureLayer",
"esri/widgets/Home",
"esri/widgets/Search",
"esri/widgets/BasemapToggle",
"esri/PopupTemplate",
"esri/tasks/Locator",
"esri/tasks/IdentifyTask",
"esri/tasks/QueryTask",
"esri/tasks/support/Query",
"esri/core/watchUtils",
"dojo/dom-construct",
"dojo/dom",
"dojo/on",
"dojo/domReady!"
], function(
Map,
MapView,
MapImageLayer,
FeatureLayer,
Home,
Search,
BasemapToggle,
PopupTemplate,
Locator,
IdentifyTask,
QueryTask,
Query,
watchUtils,
domConstruct,
dom,
on) {
// * Create a FeatureLayer instance pointing to a Map Service
var Lyr1 = new FeatureLayer({
url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/MontgomeryQuarters/MapServer/0",
opacity: 1.0,
visible: true,
var Lyr2 = new FeatureLayer({
opacity: 1.0,
visible: true,
var Lyr3 = new FeatureLayer({
opacity: 1.0,
visible: true,
var Lyr4 = new FeatureLayer({
opacity: 1.0,
visible: true,
// * Create a Popups Template
var Lyr1PopupTemplate = {
title: "Layer1",
content: "This is a Layer 1!"
Lyr1.popupTemplate = Lyr1PopupTemplate;
var Lyr2PopupTemplate = {
title: "Layer2",
content: "This is a Layer 2!"
Lyr2.popupTemplate = Lyr2PopupTemplate;
var Lyr3PopupTemplate = {
title: "Layer3",
content: "This is a Layer 3!"
Lyr3.popupTemplate = Lyr3PopupTemplate;
var Lyr4PopupTemplate = {
title: "Layer4",
content: "This is a Layer 4!"
Lyr4.popupTemplate = Lyr4PopupTemplate;
var map = new Map({
basemap: "gray",
layers: [Lyr1, Lyr2, Lyr3, Lyr4]
var view = new MapView({
container: "viewDiv",
map: map,
center: [-85.816269, 32.378512], // lon, lat
scale: 40000
view.popup.dockOptions = {
buttonEnabled: false,
breakpoint: false,
menu.click();
}, 300);
/* Creating widgets*/
var homeWidget = new Home({
view: view
view.ui.add(homeWidget, "top-left");
var searchWidget = new Search({
view: view,
view.ui.add(searchWidget, {
position: "top-right"
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Denis,
   You forgot to add "dojo/query", to your require array.
Den-GIS
Robert,
Great, it worked.
Thank you very much for your help!
