Creating New Feature From Geometry Object
1333
06-25-2014 04:30 AM
DuncanRager
Greetings,
I'm interested in passing a geometry object with certain attributes to an exposed feature class for committed edits. Essentially, I want to manually create a new feature without the template pane or editor widget. The geometry and attributes are both pre-defined, and the user just needs to select one pair from a group and push an "Add to Geodatabase" button.
I'm reading through the documentation and I can't see a clear way to do this. I see that if I don't want the pane or widget, then I need to use a geometry service, but I don't see a "create feature" method, or something that accepts a geometry object or attributes.
Thanks for the help,
Colin
DuncanRager
Figured things out so I figured I'd offer the pretty straight-forward solution here. Not sure why I couldn't find it to start, but simply put, you use the applyEdits() method on a feature layer, supplying it with a JSON formatted array of graphics/geometries and attributes.
Here's the code:
function showResults(featureSet) {
       // Clear prior graphics
       map.graphics.clear();
       // Assign symbology to selected features
       var parcelSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
           new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
           new dojo.Color([98, 194, 204]), 2), new dojo.Color([98, 194, 204, 0.5]));
       // Put result in array
  var resultFeatures = featureSet.features;
  if (resultFeatures.length > 0) {
   // Empty out array for new features
   features = [];
   // Loop through each feature (here it's limited to one feature)
   for (var i=0, il=resultFeatures.length; i<1; i++) {
     var feature = resultFeatures;
     feature.setSymbol(parcelSymbol);
     var geometry = feature.geometry;
     var parcelGraphic = new esri.Graphic(geometry);
     var attr = {};
     parcelGraphic.setAttributes(attr);
     features.push(parcelGraphic);
Hope it helps,
Colin
