Popup on vertex of polygon
1302
05-29-2013 11:20 AM
EduardoCarvalho
I didn't find nothing about how put popup on vertex of the polygon, all event are for polygon, not for vertex of the polygon. It's possible?
My intention. Each vertex will have popup containing input text that will search and update an address point (vertex of the polygon) to the new address.
Obs. I found a solution, but I would use the edit of polygon.
VinayBansal
You can use vertex click event
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/edit.html#onvertexclick
But this will work when edit_vertices tool is active
editToolbar.activate(esri.toolbars.Edit.EDIT_VERTICES , evt.graphic)
VinayBansal
EduardoCarvalho
vinaybansal thank you very much.
this method was that i needed
GrantCrosswell
Im new to JS and would like to use the editToolbar out of the box as much as we can.
Were you able to return the graphic coordinate to be edited from the event "vertex-click"?
if so would you be able to offer a little more code to show how this is done.
Ideally I'd like a click to be able to edit the coordinates of the vertex from the editToolbar.
Thank you
