Creating a custom AMD widget with map as the base
1804
01-16-2013 10:30 AM
JamesVillanueva
Does anyone have an example of creating a custom map widget using the ESRI map as the base? My first attempt:
define([
    "esri/map",
    "dojo/_base/declare"
  function (map, declare)
  //widget declaration
  return declare("my.Map", [map],
    constructor : function ()  {},
    postCreate : function ()
      this.inherited(arguments);
I ran into the following error: mixin #0 is not a callable constructor.
ReneRubalcava
Esri Frequent Contributor
esr/map doesn't actully return an object, not last I checked.
You could try declare('mymap', [esri.Map], { ... });
JamesVillanueva
That did the trick, thanks.
