Construct Esri Portal with alwaysUseProxy = true
795
07-17-2014 05:07 AM
GertConradie
Hi
I have a scenario where I have the following JavaScript:
esriConfig.defaults.io.alwaysUseProxy = true;
var myPortal = new esriPortal.Portal("http://www.arcgis.com");
Then, the Portal construction url is received by the proxy handler as:
     http%3a%2f%2fwww.arcgis.com%2fsharing%2frest%2faccounts%2fself%3fculture=en-za%3ff%3djson
And the decode form, retrieved with this:
string uri = context.Request.Url.Query.Substring(1);
Resolve uri to
"http://www.arcgis.com/sharing/rest/accounts/self?culture=en-za?f=json"
Which should be:
"http://www.arcgis.com/sharing/rest/accounts/self?culture=en-za&f=json"
For now I can work around it by don't set "alwaysUseProxy = true", and use "urlUtils.addProxyRule" instead., but is this a bug?
Regards, g
