Click on feature, open hyperlink... Any Suggestions?
1688
06-03-2014 07:09 AM
ChristopherCarr
I'm looking for any leads from anyone who has used an onclick event to directly open a hyperlink (stored as an attribute) instead of opening a popup window.  I'm currently using the tooltip on hover and want to open a hyperlink on click.  Any help would be greatly appreciated!
JakeSkinner
Esri Esteemed Contributor
Hi Christopher,
You could do the following:
var featureLayer = new FeatureLayer(<service url>,{
    mode: FeatureLayer.MODE_ONDEMAND,
    outFields: ["*"]
on(featureLayer, "click", function(evt){
  url = evt.graphic.attributes.<field name>;
  window.open(url);
ChristopherCarr
JSkinn3, thanks for the info.  I'm actually using non-AMD modules trying to rewrite it to match my application.  I've tried giving it a try, but can't figure out where I'm going wrong.  Any help would be appreciated!
var featureLayer = new esri.layers.FeatureLayer(<service url>,{
  mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
  outFields: ["*"],
featurelayer.on("click", openHyperlink);
function openHyperlink(evt){
  window.open(url);
Hi Christopher,
    outFields: ["*"]
  window.open(url);
JakeSkinner
Try the following:
  outFields: ["*"],
dojo.connect(featureLayer, "onClick", openHyperlink);
  window.open(url);
ChristopherCarr
JSkinn3, thank you so much!  This worked beautifully!
