Check MapService Availability
1010
10-03-2012 11:56 PM
demdeberanz
Hi guys,
   before to start the user processing on the map in a web application, i.e. loading panels, features, connecting events, etc..., I would like to check if the mapService used within the application is available and working. What I want is to set up an error handling procedure.
How to do this?Is there a specific function or attribute or request in the API to do this?
Thank you very much.
Krystianp
when you creates an object for layer, you can use build-in method onError - its tests if service is avaliable
for example:
var baseMap = new esri.layers.ArcGISDynamicMapServiceLayer('http://youservice', {
baseMap.onError = function(error) {
 console.log(error);
EDIT:
but it only launch when the service link is correct link to your arcgis server. If you add wrong address to whole arcgis server it will NOT fires up.
