check box in TOC widget
1083
12-05-2012 09:38 AM
Shu-RongKuo
Hi.
I am using the sample code TOC.  I want to check which check boxes are click to retireve the relataive attributes.  How to check which check boxes are checked ?
thanks for the help.
danbecker
Hi.
loop over the legendLayers array which holds the serviceLayer's and check the boolean visible property.
something like this:
dojo.forEach(legendLayers, function(layer){
    if(layer.layer.visible){
        console.log('this layer is checked and turned on');
    }else{
        console.log('this layer is off');
