Change popup feature menu heading - 4.28
2224
02-05-2024 09:28 AM
MatthewDriscoll
*edit for more context
There seems to be a new item of heading in the search feature menu popup.   How do I change that from "Untitled" to something else or to get rid of it completely?
4.21 - Link Example - 4.21
4.28 - Link Example - 4.28
JoelBennett
MVP Regular Contributor
The value of that heading should be the same as the title property for the layer containing the graphics.  If your layer doesn't have a title, that could explain it.  Or, if you're not using a layer and adding your graphics directly to the MapView's graphics collection instead, that might explain it as well.
MatthewDriscoll
Both examples given use the exact same code.
function createPopupTemplate(){
      const urlTax = "https://ks1418.cichosting.com/ttp/tax/Search/search_tax_results.aspx?";
      const urlRC = "https://www.jfksgis.us/prc/"
      var parInfo = 'https://www.jfksgis.us/JFKSParcelSearch/parcelInformation.html';
      var platy = "Replace($feature.Plat_HL, ' ', '%20')"
      return{
        title:
          "<b>Owner:</b> {PartyName_1} " +
          "<br /><b>Address: </b> {PropertyAddress}" +
          "<br><b>Property Number: </b> {PropertyNumber}" +
          "<br><b>Appraisal:</b> ${RP_AprTot}",
        outFields: ["*"],
        content:
              type: "fields",
              fieldInfos:[
                  fieldName: "QuickRefID",
                  label: "Quick Ref ID",
                  fieldName: "ACRES",
                  label: "Acres",
                  format:{
                    places: 2,
              type: "text",
              text: "<a class='hyperlinkURL' target='_blank' href=" + parInfo + "?PropertyID={PropertyID}&PID={PID}&PropNum={PropertyNumber}>Parcel Information</a>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp<a class='hyperlinkURL' target='_blank' href=" + urlTax + "PID={PID}>Tax Information</a>"
              type: "text",
              text: "<a class='hyperlinkURL2' target='_blank' href=https://{expression/platlinked}>View Plat</a>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp<a class='hyperlinkURL' href=" + urlRC + "{PropertyNumber}.pdf>Property Record Card</a>",
          expressionInfos:[
              expression: platy,
          fieldInfos:[{
            fieldName: "RP_AprTot",
            label: "Total Appraised Value",
            format: {
              places: 2,
              digitSeparator: true,
JoelBennett
MatthewDriscoll
The layer does have a title, see below.  I do add graphics directly, but the popup template is on the feature layer.  I will play around with it.   Is there a way to just not show the heading at all?
    const parcelLayer = new FeatureLayer({
      url: "https://www.jfksgis.us/server/rest/services/BaseLayers/JFKSBaseMapLayers/MapServer/3",
      title: "parcel Layer",
      popupTemplate : createPopupTemplate(),
      listMode: "hide",
      outFields:["*"]
MatthewDriscoll
You were correct.  I used the graphics not the layer.
https://codepen.io/mbdriscoll/pen/GReBgYd
