*edit for more context
There seems to be a new item of heading in the search feature menu popup. How do I change that from "Untitled" to something else or to get rid of it completely?
4.21 - Link Example - 4.21
4.28 - Link Example - 4.28
The value of that heading should be the same as the title property for the layer containing the graphics. If your layer doesn't have a title, that could explain it. Or, if you're not using a layer and adding your graphics directly to the MapView's graphics collection instead, that might explain it as well.
Both examples given use the exact same code.
function createPopupTemplate(){ const urlTax = "https://ks1418.cichosting.com/ttp/tax/Search/search_tax_results.aspx?"; const urlRC = "https://www.jfksgis.us/prc/" var parInfo = 'https://www.jfksgis.us/JFKSParcelSearch/parcelInformation.html'; var platy = "Replace($feature.Plat_HL, ' ', '%20')" return{ title: "<b>Owner:</b> {PartyName_1} " + "<br /><b>Address: </b> {PropertyAddress}" + "<br><b>Property Number: </b> {PropertyNumber}" + "<br><b>Appraisal:</b> ${RP_AprTot}", outFields: ["*"], content: [ { type: "fields", fieldInfos:[ { fieldName: "QuickRefID", label: "Quick Ref ID", }, { fieldName: "ACRES", label: "Acres", format:{ places: 2, } }, ] }, { type: "text", text: "<a class='hyperlinkURL' target='_blank' href=" + parInfo + "?PropertyID={PropertyID}&PID={PID}&PropNum={PropertyNumber}>Parcel Information</a>      <a class='hyperlinkURL' target='_blank' href=" + urlTax + "PID={PID}>Tax Information</a>" }, { type: "text", text: "<a class='hyperlinkURL2' target='_blank' href=https://{expression/platlinked}>View Plat</a>      <a class='hyperlinkURL' href=" + urlRC + "{PropertyNumber}.pdf>Property Record Card</a>", }, ], expressionInfos:[ { name: "platlinked", expression: platy, }, ], fieldInfos:[{ fieldName: "RP_AprTot", label: "Total Appraised Value", format: { places: 2, digitSeparator: true, } }, ], } };
The layer does have a title, see below. I do add graphics directly, but the popup template is on the feature layer. I will play around with it. Is there a way to just not show the heading at all?
const parcelLayer = new FeatureLayer({ url: "https://www.jfksgis.us/server/rest/services/BaseLayers/JFKSBaseMapLayers/MapServer/3", title: "parcel Layer", popupTemplate : createPopupTemplate(), listMode: "hide", outFields:["*"] });
You were correct. I used the graphics not the layer.
https://codepen.io/mbdriscoll/pen/GReBgYd
