Change in identity manager between 2.5 and 2.6
11760
45
01-31-2012 07:22 AM
JeffPace
My identity manager works at 2.5.  I don't have any custom code in it at the moment, it just hits the first secure service and prompts for login (AWESOME THANK YOU)
when I change my application to 2.6, firebug throws and error saying
tokenserviceurl not defined
and hangs login.
What changed?
JeffPace
Let's try this:
var serverInfo = new esri.ServerInfo(); serverInfo.server = 'https://www.mymanatee.org'; serverInfo.tokenServiceUrl = 'https://www.mymanatee.org/arcgis/tokens/generateToken';           esri.id.registerServers([serverInfo]);
Can you let us know if that works?
esri.ServerInfo is not a constructor
[Break On This Error] var serverInfo = new esri.ServerInfo();
derekswingley1
What is version of ArcGIS Server are you using (including service pack)?
JeffPace
10.03
10 service pack 3 for java
derekswingley1
2.5 tried to guess the tokenServiceUrl but 2.6 does not.
Can you post the response from your REST info endpoint? Here's an example using servicesbeta.esri.com:  http://servicesbeta.esri.com/ArcGIS/rest/info?f=json&pretty=true
And the response:
  "currentVersion" : 10.02,
  "soapUrl" : "http://WEBAPI20BETA/arcgis/services",
  "secureSoapUrl" : "https://WEBAPI20BETA:443/arcgis/services",
  "authInfo" : {
    "isTokenBasedSecurity" : true,
    "tokenServicesUrl" : "https://servicesbeta.esri.com/ArcGIS/tokens"
JeffPace
And the response:
  "authInfo" : {
Hmm, having trouble I get garbage back.
This is a secure service (obviously) with ssl enabled.
derekswingley1
Do you see a call to /ArcGIS/info when you load your page? You should see this in firebug or chrome dev tools.
You can see this in our identity manager sample:  https://servicesbeta.esri.com/demos/widget/widget_identifymanager.html
JeffPace
I tried that same like on my server that does not have security, and it only works on port 8343 with same response.  8399 gives page not found, is that correct?
JeffPace
I can't test at the moment.  This is our production server and it is in use, and unfortunately we do not have a development environment to support ssl so we have to deploy to test (i know, worst business practice).
Once the field guys are done for the day i will roll production back to 2.6 and test.
derekswingley1
Looking forward to what you find.
JeffPace
anything else i can test in the meantime?
