Change in identity manager between 2.5 and 2.6
11908
45
01-31-2012 07:22 AM
JeffPace
My identity manager works at 2.5.  I don't have any custom code in it at the moment, it just hits the first secure service and prompts for login (AWESOME THANK YOU)
when I change my application to 2.6, firebug throws and error saying
tokenserviceurl not defined
and hangs login.
What changed?
derekswingley1
anything else i can test in the meantime?
Seeing the output from your server's /ArcGIS/info would be good.
JeffPace
2.5 works perfectly.  2.6 no call is being made to token service
its public now
https://www.mymanatee.org/gisapps/mapviewer/index.jsp?type=utilitiesinfrastructure
<removed> for username and password.
derekswingley1
What kind of security are you using? I was assuming you were using token based but /ArcGIS/info says that's not enabled:  http://www.mymanatee.org/arcgis/rest/info?f=pjson
 "currentVersion": 10.03,
 "soapUrl": <snip>
 "secureSoapUrl": <snip>
 "authInfo": {"isTokenBasedSecurity": false}
JeffPace
 "soapUrl": <snip>
yes its token based, it is behind a web application firewall (modproxy).
JeffPace
arcgis/rest/info does not resolve to the server that has the security on it.  We only allow access to the sub folder.
JeffPace
"soapUrl": "http://mcg-ap-arcsvr02:8399/arcgis/services",
"secureSoapUrl": "https://mcg-ap-arcsvr02:8343/arcgis/services",
"authInfo": {
  "isTokenBasedSecurity": true,
  "tokenServicesUrl": "http://MCG-AP-ARCSVR02:8399/arcgis/tokens"
JeffPace
had to change mine back.  here is a simple working example
http://www.mymanatee.org/gisapps/mapviewer/test26.htm
uses the 2.6 api and hangs
changing the code to 2.5 it works
http://www.mymanatee.org/gisapps/mapviewer/test25.htm
all i did was take the sample, change the proxy page to my own, remove the feature layer, and change the other layer to my secure service.
KellyHutchins
Esri Notable Contributor
It might be worth testing setting the tokenServiceUrl. You can do this using the following code:
  var serverInfo = new esri.ServerInfo();
  serverInfo.server = 'http://sampleserver3.arcgisonline.com';
  serverInfo.tokenServiceUrl = 'http://sampleserver3.arcgisonline.com/arcgis/tokens/generateToken';
  esri.id.registerServers([serverInfo]);
JeffPace
I will try that in the morning.  Curious though, how do you do that if you have more than one secure service on more than one server?
KellyHutchins
registerServers takes an array of ServerInfo objects so you'd just need to create a ServerInfo object for each server and add it to the array you provide to registerServers. See the IdentityManagerBase help topic for details:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/identitymanagerbase.ht...
