centering in simple tiled map
876
05-16-2013 06:56 AM
GyeyoungChoi
Hello,
I made a very simple map but it won't change the initial map center.
can anyone give me some advice?
Thank you,
Jack
    <script>
      dojo.require("esri.map");
      var map;
      function init() {
        map = new esri.Map("mapDiv", {
   center:[-96,30],
        var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/FCOR/BaseMapTileTest/MapServer", {
        map.addLayer(dynamicMapServiceLayer);
      dojo.ready(init);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
JohnGravois
what is the coordinate system of your dynamicMapService?  the lat/long values you are currently using would only help you center the map if your own service was published in WGS84 or Web Mercator.
try adding a basemap property (which ensures a web mercator tiledMapService is loaded first) in the map constructor to see what i mean.
                        basemap: "gray",
   center:[-96,30],
