Geoprocessing Task samples?
2784
05-16-2013 07:06 AM
TonyMonsour
Where did the geoprocessing task samples go for the JS API? Looks like they cleaned up and removed a lot of bloat but took out all the gp task examples in the process.
KellyHutchins
Esri Notable Contributor
Hi Tony,
We did remove many samples from the Table of Contents to remove samples with duplicate functionality, older samples etc. However they are still available via the search tool. Try searching for Geoprocessing and you'll see many more results than display in the TOC.
http://developers.arcgis.com/en/javascript/jssamples/#search/Geoprocessing
derekswingley1
I'll also add that there are geoprocessing specific samples in the analytics category:  http://developers.arcgis.com/en/javascript/jssamples/#analytics
