Can we add a image using world file
789
11-17-2022 03:05 AM
DivyaArora
We have tried to render an image using the data extent(https://developers.arcgis.com/javascript/latest/sample-code/layers-medialayer-images/). We are looking into the scenario where we can render the image using the worldfile format. Is it possible
Sage_Wall
Hi @DivyaArora ,
It's currently not possible to directly position a MediaLayer using a worldfile. You can use a defined extent and rotation, corners, or control points. You might be able to calculate one of these from the worldfile, but it's not built in to the ArcGIS API for JavaScript.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-ImageElement.html#...
