Can't zoom to feature from Datagrid
7563
26
06-09-2014 05:37 AM
RyanSellman
I have a find task in my application that returns features that are points, lines and polygons.  I can get the search to populate the datagrid but I am having problems with my onRowClickHandler function and zooming to those features from the datagrid.  I've been searching through the forums and see that zooming to a point from the datagrid has been an issue for others, but I can't find a solution that works for me.  Here is some code that shows the findtask and what I have for the onRowClickHandler function.
I get the error: "Uncaught TypeError: Cannot read property 'getExtent' of undefined" when the onRowClickHandler function is fired.
findDistrictTask = new FindTask("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES/MapServer/");          map.on("load", function () {             findDistrictParams = new FindParameters();             findDistrictParams.returnGeometry = true;             findDistrictParams.layerIds = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12];             findDistrictParams.searchFields = ["NAME, UNAME, PUMPID, PIPEID, PlantID, Name"];             findDistrictParams.outSpatialReference = map.spatialReference;         });          function doDoesDistrictFind() {             findDistrictParams.searchText = dom.byId("doesDistrictText").value;             findDistrictTask.execute(findDistrictParams, showResults);         }           function showResults(results) {             var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));             var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);             var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));             map.graphics.clear();             var dataForGrid = [];             arrayUtils.map(results, function (result) {                 var graphic = result.feature;                 dataForGrid.push([result.layerName, result.foundFieldName, result.value]);                 switch (graphic.geometry.type) {                 case "point":                     graphic.setSymbol(markerSymbol);                     break;                 case "polyline":                     graphic.setSymbol(lineSymbol);                     break;                 case "polygon":                     graphic.setSymbol(polygonSymbol);                     break;                 }                 map.graphics.add(graphic);             });             var data = {                 items: dataForGrid             };             var store = new ItemFileReadStore({                 data: data             });              var grid = registry.byId("grid");              grid.setStore(store);             grid.on("rowclick", onRowClickHandler);              map.centerAndZoom(center, zoom);         }          function onRowClickHandler(evt) {             var clickedFeature = evt.grid.getItem(evt.rowIndex).OBJECTID;             var selectedFeature = arrayUtils.filter(map.graphics.graphics, function (graphic) {        return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedFeature);       });        var featureExtent = selectedFeature.geometry.getExtent();    var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());    var mappoint = map.toMap(screenpoint);        map.centerAt(mappoint);                 if (selectedFeature.geometry.declaredClass == 'esri.geometry.Point') {                 map.centerAt(selectedFeature.geometry);             } else {                 var featureExtent = selectedFeature.geometry.getExtent();                 var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());                 var mappoint = map.toMap(screenpoint);                 map.centerAt(mappoint);             }       }
Does anyone have any idea what I am doing wrong or a way to zoom to all feature types from a datagrid?  Thanks in advance!!!
TimWitt
When it finds lines or points does it highlight them?
RyanSellman
Yes, the found points and lines are highlighted on the map with the correct assigned symbology.
Thanks again for helping me with this!
LuciHawkins
Hey,
This is the onRowClickHandler that I use:
var clickedObjectf = grid.getItem(evt.rowIndex).OBJECTID;
var selectedObjectf;
var distance = 50;
dojo.forEach(map.graphics.graphics, function(graphicf) {
  if ((graphicf.attributes) && graphicf.attributes.OBJECTID === clickedObjectf) {
   selectedObjectf = graphicf;
   return;
if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point'){
   var PointExtent = new esri.geometry.Extent({
   "xmin" : selectedObjectf.geometry.x - distance,
   "ymin" : selectedObjectf.geometry.y - distance,
   "xmax" : selectedObjectf.geometry.x + distance,
   "ymax" : selectedObjectf.geometry.y + distance,
   "spatialReference" : {
    "wkid" : 102100
   map.setExtent(PointExtent);
else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polygon'){
   var selectedParcel = selectedObjectf.geometry.getExtent();
   map.setExtent(selectedParcel);
It sets a different extent based upon whether the selected object in the row is a point or a polygon.  You can add another "else if" for polyline similar to:
else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polyline'){
   var selectedStreet = selectedObjectf.geometry.getExtent();
   map.setExtent(selectedStreetl);
Luci
RyanSellman
Luci,
Thank you for your response!  I tried implementing something very similar before but kept getting the error:
Uncaught TypeError: Cannot read property 'geometry' of undefined".
When I use the code you suggested, I get the same exact error in Chrome.
In firebug, I get:
"TypeError: selectedObjectf is undefined".
I have to be missing something small.  Any thoughts??
Thank you!
LuciHawkins
Are you using Legacy or AMD?  Did you define point, polygon, and polyline.
AMD Style:
require(["...whatever else you are defining, "esri/geometry/Point", "esri/geometry/Polyline", "esri/geometry/Polygon",....end of your define"], function(....etc..., Point, Polyline, Polygon, ....etc..){
Legacy Style:
dojo.require("esri.geometry.Point");
dojo.require("esri.geometry.Polyline");
dojo.require("esri.geometry.Polygon");
Luci
RyanSellman
That may be my issue.  I am using AMD and have defined "esri/geometry/point" but not polyline or polygon.  Going to make the change now - hopefully that's it!
Thank you!!
RyanSellman
I am sorry to pester but I am still getting an error.  I have no clue whats going on.  I defined point, polyline and polygon and added the onRowClickHandler function you use but get the following message in Chome Dev Tools:
Uncaught TypeError: Cannot read property 'getItem' of undefined
Here is the find task I am using along with the code you suggested:
              if (results.length > 0) {
                      case "point":
                          break;
                      case "polyline":
                          break;
                      case "polygon":
                          break;
                      return result.feature.attributes;
                  var data = {
                      items: dataForGrid
                      data: data
              } else {
                  alert("No Utility Feature found!  Please enter a valid UNAME, PIPEID, Plant ID, PUMPID or Name.");
          //end does district search
              var distance = 50;
              dojo.forEach(map.graphics.graphics, function (graphicf) {
                      return;
              if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point') {
                      "xmin": selectedObjectf.geometry.x - distance,
                      "ymin": selectedObjectf.geometry.y - distance,
                      "xmax": selectedObjectf.geometry.x + distance,
                      "ymax": selectedObjectf.geometry.y + distance,
                      "spatialReference": {
                          "wkid": 102100
              } else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polygon') {
The graphics for all 3 feature types are drawing in the correct place and attributes are populating the grid, I just can't get the zoom to work.
Any idea why is doesn't like "getItem"
Ryan
KenBuja
MVP Esteemed Contributor
It looks like a matter of scope. You declare the variable grid in the function "showResults"
Since this is declared locally within that function, it isn't visible to other functions (like "onRowClickHandler")
You'll have to either declare the variable globally, or declare it again within "onRowClickHandler"
RyanSellman
Ken,
Thanks very much for the comment and insight.  It is appreciated as I continue to learn.
So, I made the adjustment to the onROwClickHandler function as shown here:
              var distance = 50;
                      return;
                          "wkid": 102100
Still getting the same issue with 'getItem'
What's odd to me, is when I add the function from this sample on the API site, it works.
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID;
          var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId);
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
When just a polygon is returned to the grid it works, just a line, it works.  But when there is a combination of features (a point and a polygon/a point and a line) returned to the grid, nothing works at all.  The presence of a point feature disables the function from working at all.
KenBuja
You may not notice, but there is a difference between those two functions in the way the grid is referenced. The one from the sample gets the grid from the evt passed into it
Have you tried that with your version?
    //var grid = registry.byId("grid");
    var clickedObjectf = evt.grid.getItem(evt.rowIndex).OBJECTID;
