Can't zoom to feature from Datagrid
7484
26
06-09-2014 05:37 AM
RyanSellman
I have a find task in my application that returns features that are points, lines and polygons.  I can get the search to populate the datagrid but I am having problems with my onRowClickHandler function and zooming to those features from the datagrid.  I've been searching through the forums and see that zooming to a point from the datagrid has been an issue for others, but I can't find a solution that works for me.  Here is some code that shows the findtask and what I have for the onRowClickHandler function.
I get the error: "Uncaught TypeError: Cannot read property 'getExtent' of undefined" when the onRowClickHandler function is fired.
findDistrictTask = new FindTask("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES/MapServer/");          map.on("load", function () {             findDistrictParams = new FindParameters();             findDistrictParams.returnGeometry = true;             findDistrictParams.layerIds = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12];             findDistrictParams.searchFields = ["NAME, UNAME, PUMPID, PIPEID, PlantID, Name"];             findDistrictParams.outSpatialReference = map.spatialReference;         });          function doDoesDistrictFind() {             findDistrictParams.searchText = dom.byId("doesDistrictText").value;             findDistrictTask.execute(findDistrictParams, showResults);         }           function showResults(results) {             var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));             var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);             var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));             map.graphics.clear();             var dataForGrid = [];             arrayUtils.map(results, function (result) {                 var graphic = result.feature;                 dataForGrid.push([result.layerName, result.foundFieldName, result.value]);                 switch (graphic.geometry.type) {                 case "point":                     graphic.setSymbol(markerSymbol);                     break;                 case "polyline":                     graphic.setSymbol(lineSymbol);                     break;                 case "polygon":                     graphic.setSymbol(polygonSymbol);                     break;                 }                 map.graphics.add(graphic);             });             var data = {                 items: dataForGrid             };             var store = new ItemFileReadStore({                 data: data             });              var grid = registry.byId("grid");              grid.setStore(store);             grid.on("rowclick", onRowClickHandler);              map.centerAndZoom(center, zoom);         }          function onRowClickHandler(evt) {             var clickedFeature = evt.grid.getItem(evt.rowIndex).OBJECTID;             var selectedFeature = arrayUtils.filter(map.graphics.graphics, function (graphic) {        return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedFeature);       });        var featureExtent = selectedFeature.geometry.getExtent();    var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());    var mappoint = map.toMap(screenpoint);        map.centerAt(mappoint);                 if (selectedFeature.geometry.declaredClass == 'esri.geometry.Point') {                 map.centerAt(selectedFeature.geometry);             } else {                 var featureExtent = selectedFeature.geometry.getExtent();                 var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());                 var mappoint = map.toMap(screenpoint);                 map.centerAt(mappoint);             }       }
Does anyone have any idea what I am doing wrong or a way to zoom to all feature types from a datagrid?  Thanks in advance!!!
RyanSellman
I have tried that with no luck, but with a different error:
This:
              var clickedObjectf = evt.grid.getItem(evt.rowIndex).OBJECTID;
              var selectedObjectf;
              var distance = 50;
              dojo.forEach(map.graphics.graphics, function (graphicf) {
                  if ((graphicf.attributes) && graphicf.attributes.OBJECTID === clickedObjectf) {
                      selectedObjectf = graphicf;
                      return;
              if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point') {
                  var PointExtent = new esri.geometry.Extent({
                      "xmin": selectedObjectf.geometry.x - distance,
                      "ymin": selectedObjectf.geometry.y - distance,
                      "xmax": selectedObjectf.geometry.x + distance,
                      "ymax": selectedObjectf.geometry.y + distance,
                      "spatialReference": {
                          "wkid": 102100
                  map.setExtent(PointExtent);
              } else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polygon') {
                  var selectedParcel = selectedObjectf.geometry.getExtent();
                  map.setExtent(selectedParcel);
returns this error:
"Uncaught TypeError: Cannot read property 'geometry' of undefined"
at this line of code:
KenBuja
MVP Esteemed Contributor
Are you sure you're assigning a value to selectedObjectf  in this section of your code?
        return;
I would suggest you start learning how to debug your code using some of the build-in developer tools in the different browsers. There's a video of the session "Tips and Tricks for Debugging Apps Built with ArcGIS API for JavaScript" here that you can watch.
RyanSellman
Ken,
I appreciate your help with this as well as the resource you have given me.  I will definitely watch it and continue to plug away at this.
Best,
Ryan
LuciHawkins
Hey Ryan,
In my app I use the variable "graphicf".  In your routine, you use the variable "graphic".  Ken was onto something.  Change graphicf to graphic (in all places in the onRowClickHandler)  and see if that works.
Luci
RyanSellman
Hi Luci,
Thanks for the note!  I made the changes throughout the function but I still can't get it to work correctly.  I have the following code in my app and it says it can't read the property 'geometry' of undefined.
var clickedObjectf = grid.getItem(evt.rowIndex).OBJECTID;
var distance = 50;
dojo.forEach(map.graphics.graphics, function(graphicf) {
return;
if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point'){
"xmin" : selectedObjectf.geometry.x - distance,
"ymin" : selectedObjectf.geometry.y - distance,
"xmax" : selectedObjectf.geometry.x + distance,
"ymax" : selectedObjectf.geometry.y + distance,
"spatialReference" : {
"wkid" : 102100
else if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Polygon'){
From one of the samples on the API site, I tweaked it a little.  Still not working but I get a new error that says it can't read the property declaredClass of undefined.
 var selectedObjectf = arrayUtils.filter(map.graphics.graphics, function (graphicf){
  return ((graphicf.attributes) && graphicf.attributes.OBJECTID === clickedObjectf);
 var distance = 50;
    "wkid": 102100
I really don't know what I am doing wrong, but I will continue to plug away in hopes of a solution.
Thanks again for your suggestion and help!
Ryan
RyanSellman
Okay so I think I got it working...part of the problem was that my onRowClickHandler function couldn't handle point features, but as indicated above, the suggestions for this function still didn't get things working. The showResults function was the larger part of the problem. Initially, the info being pushed to the datagrid was the resulting layer name, found field name and found value. I wanted to employ this method since I am searching a service with multiple layers and returning all records to one datagrid - so a search could potentially return results from multiple layers if the criteria isn't specific enough. For some reason, the onRowClickHandler function couldn't get at the geometry of each feature returned. Here is the code that had been giving me issues:
              if (results.length > 0) {
                      case "point":
                          break;
                      case "polyline":
                          break;
                      case "polygon":
                          break;
                      return result.feature.attributes;
                  var data = {
                      items: dataForGrid
                      data: data
              } else {
                  alert("No Utility Feature found!  Please enter a valid UNAME, PIPEID, Plant ID, PUMPID or Name.");
I adjusted it with the below code, and now the onRowClickHandler routine (provided to me by Luci) is working for all feature types.
                var items = arrayUtils.map(results, function (result) {
                      case "point":
                          break;
                      case "polyline":
                          break;
                      case "polygon":
                          break;
                  var data = {
        identifier: "OBJECTID",
        label: "OBJECTID",
                      items: items
                      data: data
              } else {
Now, displaying attributes in a useful way in the datagrid will be the next challenge.
Thanks to all for helping me tackle this! It is much appreciated!
Ryan
KenBuja
Glad to hear you got it working.
You should click the check mark on the post that best answered your question (even if it's yours) to help those who may be searching on this topic later.
