calcite-shell-panel resize
2424
01-11-2023 03:58 PM
dcarson1661
I'm struggling to make a calcite-shell-panel "resizable". The docs suggest this should work, but I've been unable to implement it.  I'm assuming setting resizable = "true" will enable a grab handle on the element. Seems like I'm missing something.
Thanks in advance for any help on this!
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
    <title>Layout</title>
    <script src="https://js.arcgis.com/calcite-components/1.0.0-beta.99/calcite.esm.js" type="module"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/calcite-components/1.0.0-beta.99/calcite.css" />
    <script src="https://js.arcgis.com/4.25/"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/4.25/esri/themes/light/main.css" />
  </head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    body {
      display: flex;
    calcite-loader {
      align-self: center;
      justify-self: center;
    #header-title {
      margin-left: 1rem;
      margin-right: 1rem;
    #info-content {
      padding: 0.75rem;
    calcite-rating {
      margin-top: 0.25rem;
  </style>
  <body>
    <calcite-loader></calcite-loader>
    <calcite-shell>
      <h2 id="header-title" slot="header">Title Goes here</h2>
      <calcite-shell-panel slot="panel-start" resizable detached="false">
        <calcite-panel heading="Side Panel Heading">
          <calcite-action icon="reset" text-enabled text="Reset" slot="header-menu-actions"></calcite-action>
        </calcite-panel>
      </calcite-shell-panel>
      <div slot="center-row" id="viewDiv"></div>
    </calcite-shell>
  </body>
 <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/widgets/Search",
      "esri/widgets/Home",
      "esri/widgets/BasemapGallery",
      "esri/widgets/Expand",
    ], function(
      Map,
      MapView,
      Search,
      Home,
      BasemapGallery,
      Expand
  // Create the Map
  var map = new Map({
      basemap: "topo-vector"
  // Create the MapView
  var view = new MapView({
      container: "viewDiv",
      map: map,
      center: [-122.200, 47.295],
      zoom: 13
  //Search Widget
  const searchWidget = new Search({
      view: view
  view.ui.add(searchWidget, {
      position: "top-left",
      index: 0
  // Home button
  var homeBtn = new Home({
      view: view
  view.ui.add(homeBtn, "top-left");
    //basmap gallery
    var basemapGallery = new BasemapGallery({
      view: view,
      container: document.createElement("div")
  var bgExpand = new Expand({
      view: view,
      content: basemapGallery
  basemapGallery.watch("activeBasemap", function() {
      var mobileSize = view.heightBreakpoint === "xsmall" || view.widthBreakpoint === "xsmall";
      if (mobileSize) {
          bgExpand.collapse();
  view.ui.add(bgExpand, "bottom-right");
  //Hide Loader and show map once map is loaded.
  view.when(function() {
    document.querySelector("calcite-loader").hidden = true;
  </script>
</html>
Sage_Wall
Hi @dcarson1661 , I think all you need to add is a position property to your calcite-shell-panel. https://codepen.io/sagewall/pen/YzjVgEM
<calcite-shell-panel slot="panel-start" position="start" resizable ></calcite-shell-panel>
Sage_Wall
dcarson1661
That was it, Thank You!
LefterisKoumis
Hello. I don't seem to make the resizable property work with shell-panel slot="panel-bottom" regardless of the displayMode value.
