Bug: 4.31 continuous zoom mouse wheel not snapping to max/min scale
925
11-28-2024 11:32 PM
mattheol
Codepen: https://codepen.io/mateusz-olsztyski/pen/RNbNjNb
Previous topic: https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/bug-4-27-continuous-zoom-mouse-wh...
I'd like to report the bug again, maybe someone will fix it someday. There is a bug with continuous zoom (view.constraints.snapToZoom = false). It's impossible (most of the times) to zoom in to max scale (or zoom out to min scale) using mouse wheel.
Look at the screenshot below (I zoomed in using mouse wheel and i can't go further with mouse wheel. The only way to achieve max scale is to use '+' button).
JesseCloutier
Esri Community Manager
Hi @mattheol, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
