Buffer Graphic
6897
13
09-12-2022 11:36 AM
jaykapalczynski
Honored Contributor
I have some code below that i am using to allow the user to create a point line or polygon
Each click of the toolbox to chose between each geometry type clears the graphic layer.
What I want to do is:
After the geometry is drawn
  1. Buffer the graphic and write that geometry to another graphic and display it in the map.
  2. I will then need to query for the new graphics geometry and pass this to another function for processing
  • I have a DIV that has the current text for the graphic but I figured it might be better to query the graphic and determine the geometry type?
  • Do I need to select the single graphic in the graphic layer?
Thoughts on the easiest way to do this?
Snip from a JSFiddle I was testing in:
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Draw polyline | Sample | ArcGIS API for JavaScript 4.24</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.24/"></script>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      .topcorner{
        position:absolute;
        top:0;
        right:0;
        width: 185px;
        border: 1px solid black;
        text-align: center;
      .topcorner2{
        position:absolute;
        bottom:0;
        right:0;
        width: 185px;
        text-align: center;
      </style>
    <script>
  require([
    "esri/Map","esri/views/MapView","esri/views/draw/Draw","esri/Graphic","esri/geometry/geometryEngine","esri/geometry/support/webMercatorUtils",
      "dojo/dom",
      "dojo/domReady!"
  ], (Map, MapView, Draw, Graphic, geometryEngine, webMercatorUtils, dom) => {
    var geometryType = "nothing"
    const map = new Map({
      basemap: "gray-vector"
    const view = new MapView({
      container: "viewDiv",map: map,
      zoom: 10,
      center: [-77.367, 37.55]
    // add the button for the draw tool
    view.ui.add("clear-button", "top-left");
    view.ui.add("line-button", "top-left");
    view.ui.add("point-button", "top-left");
    view.ui.add("polygon-button", "top-left");
    const draw = new Draw({
      view: view
    document.getElementById("clear-button").onclick = () => {
      view.graphics.removeAll();
      geometryType = "nothing";
      document.getElementById("info2").textContent=geometryType;
    document.getElementById("point-button").onclick = () => {
      geometryType = "point";
      // creates and returns an instance of PolyLineDrawAction
      const action = draw.create("point");
      // focus the view to activate keyboard shortcuts for sketching
      view.focus();
     // PointDrawAction.cursor-update
      // Give a visual feedback to users as they move the pointer over the view
      action.on("cursor-update", function (evt) {
        updateVerticesPoint(evt.coordinates);
      // PointDrawAction.draw-complete
      // Create a point when user clicks on the view or presses "C" key.
      action.on("draw-complete", function (evt) {
    document.getElementById("polygon-button").onclick = () => {
      geometryType = "polygon";
      const action = draw.create("polygon");
      view.focus();
      // listen polylineDrawAction events to give immediate visual feedback
      // to users as the line is being drawn on the view.
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesPolygon
    document.getElementById("line-button").onclick = () => {
      geometryType = "line";
      const action = draw.create("polyline");
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesLine
    // https://developers.arcgis.com/javascript/latest/esri-icon-font/
    function updateVerticesPoint(coordinates) {
      //// create a polyline from returned vertices
      //if (event.vertices.length > 0) {
      //  const result = createGraphicPoint(event);
     let point = {
       type: "point", // autocasts as /Point
       x: coordinates[0],
       y: coordinates[1],
       spatialReference: view.spatialReference
     let graphic = new Graphic({
         geometry: point,
         symbol: {
         type: "simple-marker", // autocasts as SimpleMarkerSymbol
         style: "circle",
         color: [51, 102, 153, 0.8],
         outline: { // autocasts as SimpleLineSymbol
           color: [0, 0, 0],
           width: 1
     view.graphics.add(graphic);
    function updateVerticesPolygon(event) {
      if (event.vertices.length > 1) {
        const result = createGraphicPolygon(event);
    function updateVerticesLine(event) {
        const result = createGraphicLine(event);
        // if the last vertex is making the line intersects itself,
        // prevent the events from firing
        if (result.selfIntersects) {
          event.preventDefault();
    function createGraphicPoint(event) {
      const vertices = event.vertices;
      // a graphic representing the polyline that is being drawn
      const graphicPoly = new Graphic({
        geometry: {
          type: "point",
        symbol: {
          type: "simple-marker", // autocasts as new SimpleFillSymbol
          outline: {
             color: [255, 255, 255],
             width: 1
      view.graphics.add(graphicPoly);
    function createGraphicPolygon(event) {
        geometry: {
          type: "polygon",
          rings: vertices,
        symbol: {
          type: "simple-fill", // autocasts as new SimpleFillSymbol
          color: [227, 139, 79, 0.8],
          outline: {
             color: [45, 55, 255],
             width: 1
    function createGraphicLine(event) {
      const graphicLine = new Graphic({
        geometry: {
          type: "polyline",
          paths: vertices,
        symbol: {
          type: "simple-line", // autocasts as new SimpleFillSymbol
          color: [4, 90, 141],
          width: 1,
          cap: "round",
          join: "round"
      // check if the polyline intersects itself.
      const intersectingSegment = getIntersectingSegment(graphicLine.geometry);
      // Add a new graphic for the intersecting segment.
      if (intersectingSegment) {
        view.graphics.addMany([graphicLine, intersectingSegment]);
      // Just add the graphic representing the polyline if no intersection
      else {
        view.graphics.add(graphicLine);
      // return intersectingSegment
      return {
        selfIntersects: intersectingSegment
    // function that checks if the line intersects itself
    function isSelfIntersecting(polyline) {
      if (polyline.paths[0].length < 3) {
        return false;
      const line = polyline.clone();
      //get the last segment from the polyline that is being drawn
      const lastSegment = getLastSegment(polyline);
      line.removePoint(0, line.paths[0].length - 1);
      // returns true if the line intersects itself, false otherwise
      return geometryEngine.crosses(lastSegment, line);
    // Checks if the line intersects itself. If yes, change the last
    // segment's symbol giving a visual feedback to the user.
    function getIntersectingSegment(polyline) {
      if (isSelfIntersecting(polyline)) {
        return new Graphic({
          geometry: getLastSegment(polyline),
          symbol: {
            type: "simple-line", // autocasts as new SimpleLineSymbol
            style: "short-dot",
            width: 3.5,
            color: "yellow"
      return null;
    // Get the last segment of the polyline that is being drawn
    function getLastSegment(polyline) {
      const lastXYPoint = line.removePoint(0, line.paths[0].length - 1);
      const existingLineFinalPoint = line.getPoint(
        0,
      return {
        type: "polyline",
        spatialReference: view.spatialReference,
        hasZ: false,
        paths: [
            [existingLineFinalPoint.x, existingLineFinalPoint.y],
            [lastXYPoint.x, lastXYPoint.y]
       function showCoordinates(evt) {
        var point = view.toMap({x: evt.x, y: evt.y});
        //the map is in web mercator but display coordinates in geographic (lat, long)
        var mp = webMercatorUtils.webMercatorToGeographic(point);
        //display mouse coordinates
        dom.byId("info").innerHTML = mp.x.toFixed(6) + ", " + mp.y.toFixed(6);
      view.when(function(){
        //after map loads, connect to listen to mouse move & drag events
        view.on("pointer-move", showCoordinates);
</script>
  </head>
  <body>
    <!-- https://developers.arcgis.com/javascript/latest/esri-icon-font/ -->
    <div id="viewDiv">
      <div id="clear-button" class="esri-widget esri-widget--button esri-interactive" title="Clear Grpahics">
        <span class="esri-icon-erase"></span>
      </div>
      <div id="point-button" class="esri-widget esri-widget--button esri-interactive" title="Draw point">
        <span class="esri-icon-map-pin"></span>
      </div>
      <div id="line-button" class="esri-widget esri-widget--button esri-interactive" title="Draw polyline">
        <span class="esri-icon-polyline"></span>
      </div>
      <div id="polygon-button" class="esri-widget esri-widget--button esri-interactive" title="Draw polygon">
        <span class="esri-icon-polygon"></span>
      </div>
      <div class="topcorner">
         <span id="info" ></span>
      </div>
      <div class="topcorner2">
         <div id="info2">fghfghf</div>
      </div>
    </div>
  </body>
</html>
RobertScheitlin__GISP
Sorry that code was 3.x.
For 4.x it is
let buffGeom = bufferGralayer.graphics.items[0].geometry;
jaykapalczynski
Honored Contributor
That was it.... implemented perfectly.... Thanks @RobertScheitlin__GISP
@jaykapalczynski
Here are my updates to your code UI wise has a bunch of updates to how things are styled and placed. Functionally the point method was not rendering the proper buffer visualization on the screen due to the improper symbol style being used and because the map is in webmercator the geometryEngine method should be geodesicBuffer and not buffer (my mistake there).
<html>
<head>
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
  <title>Buffer Geometry</title>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .flex-container {
      height: 100%;
      display: flex;
      overflow: hidden;
    #viewDiv {
      flex: 2;
      padding: 0;
      margin: 0;
    .side-panel {
      padding: 1em;
      overflow: auto;
    .FixedHeightContainer {
      float: left;
      height: 380px;
      width: 230px;
      padding: 3px;
      background: rgb(112, 128, 144, 0.5);
    #info {
      min-height: 17px;
    .header {
      height: 30px;
      padding-top: 5px;
    .geometryResultsdiv {
      height: 345px;
      overflow: auto;
      background: #fff;
      font-size: 8px;
    .menu {
      display: table;
      width: 100%;
      border-right: none;
      box-sizing: border-box;
    .menu>div {
      display: table-row;
      background-color: white;
    .menu>div>div {
      border-right: 1px solid black;
      display: table-cell;
      text-align: center;
      vertical-align: middle;
    @media screen and (max-width: 240px) {
      .menu {
        display: block;
        float: left;
        width: auto;
        border: none;
      .menu>div {
        display: block;
      .menu>div>div {
        border: none;
        padding-right: 10px;
        display: block;
        text-align: left;
    .boxpadding {
      margin: 8px 0;
    .float-container {
      display: flex;
      padding: 2px;
      gap: 8px;
      margin: 8px 0;
    .float-child1 {
      flex: 1;
    .float-child2 {
      flex: 2;
  </style>
  <script>
    function valDistance() {
      d = document.getElementById("distance").value;
      document.getElementById("infoDistance").textContent = "Distance: " + d;
    function valType() {
      t = document.getElementById("distanceType").value;
      document.getElementById("infoType").textContent = "Type: " + t;
    require([
      "esri/Map", "esri/views/MapView", "esri/views/draw/Draw", "esri/Graphic", "esri/geometry/geometryEngine",
      "esri/layers/GraphicsLayer"
    ], (Map, MapView, Draw, Graphic, geometryEngine, webMercatorUtils, GraphicsLayer) => {
      var geometryType = "No Geometry Selected"
      let bufferGralayer = new GraphicsLayer({
      bufferGralayer.opacity = 0.5;
        basemap: "gray-vector",
        layers: [bufferGralayer]
        map: map,
        zoom: 10,
        view: view
      // THIS IS FOR THE BUTTONS IN THE SIDE BAR
      document.getElementById("clear-button2").onclick = () => {
        bufferGralayer.removeAll();
        geometryType = "No Geometry Selected";
        document.getElementById("info2").textContent = geometryType;
        document.getElementById("geometryResultsdiv").textContent = "";
      document.getElementById("point-button2").onclick = () => {
        document.getElementById("geometryResultsdiv").innerText = "";
        document.getElementById("info2").textContent = "Geometry: " + geometryType;
        view.focus();
          setTimeout(() => {
            document.getElementById("geometryResultsdiv").innerText = JSON.stringify(bufferGralayer.graphics.items[0].geometry);
          }, 200);
      document.getElementById("polygon-button2").onclick = () => {
        view.focus();
        action.on(
            "vertex-add",
            "vertex-remove",
            "cursor-update",
            "redo",
            "undo",
            "draw-complete"
      document.getElementById("line-button2").onclick = () => {
        view.focus();
        action.on(
            "vertex-add",
            "vertex-remove",
            "cursor-update",
            "redo",
            "undo",
            "draw-complete"
          updateVerticesLine
        let point = {
          x: coordinates[0],
          y: coordinates[1],
          geometry: point,
          symbol: {
            style: "circle",
            color: [70, 90, 141, 0.4],
            outline: {
              color: [47, 76, 119, 0.5],
              width: 1
        BufferGeom(graphic.geometry);
        if(event.type === 'draw-complete'){
          setTimeout(() => {
          }, 200);
          setTimeout(() => {
          }, 200);
        const graphicPnt = new Graphic({
          geometry: {
            type: "point",
          symbol: {
            color: [255, 255, 255, 0.9], //[70,90,141,0.2],
            opacity: 0.2,
            outline: {
              color: [255, 255, 255, 0.9], //[47,76,119, 0.2],
              width: 1
        view.graphics.add(graphicPnt);
        BufferGeom(graphicPnt.geometry, 500);
          geometry: {
            type: "polygon",
            rings: vertices,
          symbol: {
            outline: {
              color: [47, 76, 119],
              width: 1
        BufferGeom(graphicPoly.geometry);
          geometry: {
            type: "polyline",
            paths: vertices,
          symbol: {
            width: 1,
            cap: "round",
            join: "round"
        else {
          BufferGeom(graphicLine.geometry);
        return {
      function BufferGeom(geom) {
        var d = parseInt(document.getElementById("distance").value);
        var t = document.getElementById("distanceType").value;
        const buffGeom = geometryEngine.geodesicBuffer(geom, d, t);
        const buffgra = new Graphic({
          geometry: buffGeom,
          symbol: {
              color: [112, 128, 144],
              width: 1,
              cap: "round",
              join: "round"
        bufferGralayer.add(buffgra);
        // document.getElementById("geometryResultsdiv").innerText = JSON.stringify(userDefinedGeometry);
          return false;
            symbol: {
              style: "short-dot",
              width: 3.5,
              color: "yellow"
        return null;
          0,
        return {
          type: "polyline",
          hasZ: false,
          paths: [
          x: evt.x,
          y: evt.y
        document.getElementById("info").innerHTML = mp.x.toFixed(6) + ", " + mp.y.toFixed(6);
      view.when().then(() => {
  </script>
</head>
<body>
  <div class="flex-container">
    <div id="viewDiv"></div>
    <div class="esri-widget side-panel">
      <div>
        <h2>Geometry Selection</h2>
        <span id="info"></span>
        <div class="float-container">
          <div class="float-child1">
            <div>Distance</div>
          </div>
          <div class="float-child2">
            <select name="distance" id="distance" onchange="valDistance()" style="width:75px;">
              <option value="1"> 1</option>
              <option value="2"> 2</option>
              <option value="3"> 3</option>
              <option value="5"> 5</option>
              <option value="10"> 10</option>
            </select>
          </div>
        </div>
            <div>Unit</div>
          </div>
            <select name="distanceType" id="distanceType" onchange="valType()" style="width:75px;">
              <option value="miles">mile(s)</option>
              <option value="feet">feet</option>
              <option value="meters">meter(s)</option>
            </select>
          </div>
        </div>
        <div class="boxpadding" id="infoDistance">Distance: 1</div>
        <div class="boxpadding" id="infoType">Unit: mile</div>
        <div class="menu">
          <div>
            <div id="clear-button2" class="esri-widget esri-widget--button esri-interactive" title="Clear Grpahics">
            </div>
            <div id="point-button2" class="esri-widget esri-widget--button esri-interactive" title="Draw point">
            </div>
            <div id="line-button2" class="esri-widget esri-widget--button esri-interactive" title="Draw polyline">
            </div>
            <div id="polygon-button2" class="esri-widget esri-widget--button esri-interactive" title="Draw polygon">
            </div>
          </div>
        </div>
        <div id="info2" class="boxpadding">Geometry:</div>
        <div class="FixedHeightContainer">
          <div class="header" id="header">Results</div>
          <div class="geometryResultsdiv" id="geometryResultsdiv"> </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
jaykapalczynski
Honored Contributor
  • Cool I like the timeout  draw-complete showing the Geometry JSON Results being displayed..
  • Yea the initial code I submitted had an issue with the Point not buffering properly.  It was all down to the Variable set up for "geometryType"
  • Other changes to the text reporting as well were done well...
Cheers and thanks for your input.... learn more and more every day....
