Bing Map Projection
2834
03-05-2016 01:23 AM
NadirHussain
I add bing map layer on run time in my application as a base map.in my application i want t0 add new point of interest in my extent.whenever i add the point it add the point outside from my extent.as per my information i think it is due to bing map layer.please help me how to solve this problem.
code is given below.
Before i was doing like this
pt = new Point(txtLong, txtLat, map.spatialReference);
i changed it with below line.
   pt = new Point(txtLong, txtLat, new SpatialReference({ wkid: 4326 }));
but i found same result always in both statments. Point is always outside from my area of extent.
Please help.
RobertScheitlin__GISP
Nadir,
   Bing Basemap use the WKID of 102100 not 4326 so you need to take your points in 4326 and use WebMercatorUtils to project them to web mercator.
"esri/geometry/webMercatorUtils"
var geom = webMercatorUtils.geographicToWebMercator(pt);
Nadir,
