basemap
955
12-26-2017 02:22 AM
anjelinaponkerat
Hi
I,m using api 4.6 and i,m going to replace esri base map with my own tilled map service. I used tiled setting but it can not load my map service!!:
// Add the exaggerated elevation layer to the map's ground
// in place of the default world elevation service
var map = new Map({
var housingLyr = new TileLayer({ url: "https://tiles.arcgis.com/tiles/nGt4QxSblgDfeJn9/arcgis/rest/services/New_York_Housing_Density/MapSer..." });
ground: {
layers: [
new ExaggeratedElevationLayer()
var view = new SceneView({
container: "viewDiv",
viewingMode: "global",
map: map,
RobertScheitlin__GISP
Anjelina,
   Your code had issues.
var map = new Map({
  ground: {
    layers: [
  map: map,
map.add(housingLyr);‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Anjelina,
var map = new Map({
  ground: {
    layers: [
  map: map,
