Auto zoom to combo box select
1654
08-23-2014 02:40 PM
MayJeff
I try to select a State from a drop down menu then auto zoom to the State in map  instead of clicking the search button all the time to get the results.
Here is my code in JSFiddle.
Edit fiddle - JSFiddle
Can someone help me to take a look on the code?
Thank you.
RobertScheitlin__GISP
May Jeff,
  Sure here is the code working:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Select by state</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dojox/grid/resources/Grid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dojox/grid/resources/claroGrid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    require([
        "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/tasks/QueryTask",
        "esri/tasks/query",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
        'dojo/_base/lang',
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane", "dijit/form/ComboBox",
        "dojo/domReady!"
      ], function (
      Map, ArcGISDynamicMapServiceLayer, QueryTask, Query, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
      Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser, lang
      var queryTask, query;
      var map, center, zoom;
      var grid, pageInfo, store;
      parser.parse();
      registry.byId("stateName").on("change", doQuery);
      var initExtent = new esri.geometry.Extent({
        "xmin": -125.0552,
        "ymin": 38.7130,
        "xmax": -70.2156,
        "ymax": 48.4081,
        "spatialReference": {
          "wkid": 4326
      map = new esri.Map("map", {
        extent: initExtent
      var censusMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...", {
      map.addLayer(censusMapLayer);
      //Create Find Task using the URL of the map service to search
      queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
      function doQuery() {
        console.info("got here");
        //create the query
        var query = new Query();
        query.returnGeometry = true;
        query.outFields = ["*"];
        query.outSpatialReference = map.spatialReference;
        query.where = "(STATE_NAME) = ('" + dom.byId("stateName").value + "')";
        queryTask.execute(query, showResults);
      function showResults(results) {
        map.graphics.clear();
        var symbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
          new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
          new Color([98, 194, 204, 0.5])
        //create array of attributes
        var items = arrayUtils.map(results.features, function (result) {
          var graphic = result;
          graphic.setSymbol(symbol);
          map.graphics.add(graphic);
          return result.attributes;
        //Create data object to be used in store
        var data = {
          identifier: "STATE_NAME", //This field needs to have unique values
          label: "    STATE", //Name field for display. Not pertinent to a grid but may be used elsewhere.
          items: items
        //Create data store and bind to grid.
        store = new ItemFileReadStore({
          data: data
        var grid = registry.byId("grid");
        grid.setStore(store);
        grid.on("rowclick", onRowClickHandler);
        //Zoom back to the initial map extent
        // map.centerAndZoom(center, zoom);
        var extent = esri.graphicsExtent(map.graphics.graphics);
        map.setExtent(extent, true);
        grid.resize();
      //Zoom to the parcel when the user clicks a row
      function onRowClickHandler(evt) {
        var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).STATE_NAME;
        var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
          return ((graphic.attributes) && graphic.attributes.STATE_NAME === clickedTaxLotId);
        if (selectedTaxLot.length) {
          map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;">
      <table width="100%">
        <tr>
          <td align="center">
            <select id="stateName" dojoType="dijit.form.ComboBox">
              <!--working with search button-->
              <option>Choose State</option>
              <option>Arkansas</option>
              <option>Kansas</option>
              <option>California</option>
              <option>Florida</option>
              <option>Nevada</option>
            </select>
          </td>
        </tr>
      </table>
    </div>
    <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
      <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
        <thead>
          <tr>
            <th field="STATE_NAME">State Name</th>
            <th field="STATE_FIPS">State FIPS</th>
          </tr>
        </thead>
      </table>
    </div>
  </div>
</body>
</html>
When using AMD you have to make sure your functions that you are calling from dijits are in scope. Normally you would just add the event to the dijit in the code and not in the html.
May Jeff,
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
        "esri/tasks/query",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        'dojo/_base/lang',
        "dojo/domReady!"
      ], function (
      parser.parse();
        "xmin": -125.0552,
        "ymin": 38.7130,
        "xmax": -70.2156,
        "ymax": 48.4081,
          "wkid": 4326
        extent: initExtent
        //create the query
        var data = {
          items: items
          data: data
        grid.resize();
  </script>
</head>
        <tr>
          <td align="center">
            </select>
          </td>
        </tr>
      </table>
    </div>
        <thead>
          <tr>
          </tr>
        </thead>
      </table>
    </div>
  </div>
</body>
</html>
MayJeff
Thank you very much.  It works!
