authentication in angular
5101
10
08-26-2022 05:53 AM
Mannus_Etten
i find many examples pretty useful but all written with amd / require-syntax.
so also the example with oauth login.
so in the example there is:
  esriId.registerOAuthInfos([info]);
but that doesn't work in an angular app with es-modules. How does I do this now?
HHow do I get the OAuth-popup now?
i am looking for an example with es-modules. No amd-modules and also no "require(xxxx)"-syntax.
Portal Genius / KLIC Genius / Backup Genius
Mannus_Etten
I got it running in the end, if you place the html in the assets-folder for the oauth-callback it is solved. Files in this folder are not going through the routing mechanism.
