attach event listener to html element within standard esri popup
1256
11-26-2012 02:08 PM
DerekMiller
Hello all,
I would like to attach an event listener to an html element within a popup window. I'm basically trying to mimic the maximize button. However, I want to have more control, and therefore intend to attach the listener to a custom function and dojo animation.
Unfortunately, I cannot connect to the element within the popup via ID or Class. Any thoughts?
- d
__Rich_
What's not working?  (what have you tried?)
DerekMiller
Thanks for the response. Should have included a few things that had not worked.
First, the popup template that is creating the html element:
popupTemplate = new esri.dijit.PopupTemplate({
          title: "{building_name}",
          //description: "<h4>{building_name}</h4><hr/>{Short_Desc}",
          description: "{Short_Desc}"+"</br><div id='expandoPopLink' data-dojo-type='dijit.form.Button'></div>",
          mediaInfos: [{
            "type": "image",
            "value": {
              "sourceURL": "{image_path}",
              "linkURL": "{image_path}"
Note the the element has also been tested as an empty <div> (no dijit.form.Button), and also as a <span> with a class .expandoPopLink.
Next, the event handlers that have been tried, also note that I did not try all these at once....
expandoPopLink = document.getElementById("expandoPopLink");
       expandoPopLink = dojo.byId('expandoPopLink');
       expandoPopLink.click = function() {
         alert("turkey");
       dojo.connect(".expandoPopLink", "onClick", function() {
         alert("this works");
       expandoPopLink = dojo.query(".expandoPopLink")[0];
       expandoPopLink = document.getElementById("expandoPop");
       console.log(expandoPopLink);
       dojo.connect(expandoPopLink, "onClick", function() {
         alert("turkey");
         alert("turkey");
       dojo.connect(dijit.byId("expandoPopLink"), "onClick", function() {
         console.log("button in popup clicked");
         alert("turkey");
I've been told by another source that it's DOM methods only within the popup. I'll be testing but I look forward to your thoughts.
Thanks again,
- d
DerekMiller
- d
Using the same popupTemplate as posted above, I declared expandoPopLink as so:
then connected the event listener like this:
dojo.connect(expandoPopLink, "onclick", derek);
And the function fires. Don't know why the anonymous function route didn't fire as I expected, but this seems to work.
Still interested in any thoughts you might have. I'd like to make this application as smooth as possible.
Thanks again,
- d
