arcgis works on IE but not Chrome/Firefox
9720
29
09-03-2014 02:11 PM
NathanLindley
Map just keeps trying to load in Chrome/Firefox but works great in Internet Explorer...any ideas??
Using:
<script type="text/javascript" src="http://js.arcgis.com/3.10/"></script>
Thanks in advance for any suggestions!
NathanLindley
So after a little more digging I did find an error:
I tried adding the following require but got the same error:
dojo.require("esri/symbols/SimpleMarkerSymbol")
This is my markerSymbol var:
var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 28, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([27, 236, 86]), 0.75), new dojo.Color([255, 0, 0, 0.30]));
NathanLindley
Issue has been fixed by moving the variable declarations to after the dojo.AddOnLoad(init).  Not sure why this fixed it, but it is fixed.  Thanks for all of the suggestions!
Edit:  This is not the correct solution.  It just lets the maps load before the error occurs again and then the markers do not display.
NathanLindley
Not trying to bump/whatever, just want to make sure people know this is not a solved issue.
Thanks for all of the help!
RobertScheitlin__GISP
Nathan,
  Can you post your code or add it to a fiddle to have it reviewed for errors?
NathanLindley
Robert,
I tried to do a jsfiddle which is Edit fiddle - JSFiddle but I am not sure how to load a public map in.
Basically this code is what is causing an error in firefox/chrome but works perfect in IE:
Error:
Nathan,
  So you are using
and the correct object name is esri.symbols.SimpleMarkerSymbol
var markerSymbol = new esri.symbols.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 28, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([27, 236, 86]), 0.75), new dojo.Color([255, 0, 0, 0.30]));
NathanLindley
I thought that might be an issue so I tried that before but didn't work.
When looking at the new way to do it, I noticed the format is a bit different with the require([]), etc.  But the scalebar works fine with the dojo.require("esri.dijit.Scalebar") so it doesn't really make sense for that to be the issue.
The new way is called AMD and they way you currently have your app developed is called Legacy. You should definetly move your app to AMD. So from the fiddle it looks like you have your app in an ASPX page or something is this correct?
NathanLindley
I had a feeling that was probably the way to go but just assumed there was an easier fix since it works fine in IE.
Yep, the map is being loaded via an aspx page and was designed by my predecessor thus my lack of knowledge of GIS programming.
Nathan,
   I am really not sure why is would working IE and not in other browsers. Is this site publicly accessible?
