ArcGIS Maps SDK for JavaScript 3.46
3644
6
08-11-2024 11:48 PM
GisMan
can i still download ArcGIS Maps SDK for JavaScript 3.46 version?
CodyPatterson
MVP Regular Contributor
Hey @GisMan
It does not appear that 3.46 is publicly available for download after it had been retired: https://developers.arcgis.com/javascript/3/
Here is a FAQ that covers quite a few questions: https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/arcgis-api-for-javascript-version...
If you still have code that is running on 3.46, I would recommend following the guide to get it migrated over to the 4.x version, and if you are in dire need of it, ESRI Support may be able to help you to some extent, but with retired services, typically training on such products are discontinued to the support staff, but that's just an assumption.
Cody
CodyPatterson
Hey @GisMan
Cody
GisMan
Thanks @CodyPatterson
PalatlaSrikanth
How do we download ArcGIS JavaScript API 3.46 offline SDK
JoelBennett
Follow the instructions in this message, but change "api" in the URLs to "sdk".
JoelBennett
As of now, yes, but that could change at any time.  See this message.
GisMan
Thanks @JoelBennett
