ArcGIS JS SDK Reference unreachable
1542
8
03-16-2025 05:37 AM
ChristopheSuter
Hi there,
ArcGIS JS SDK Reference is unreachable since Saturday.
see https://developers.arcgis.com/javascript/latest/api-reference/esri-Camera.html
2 Solutions
BjornSvensson
This should be fixed with our next documentation update. Hopefully around 3pm PDT today.
Noah-Sager
To close the loop on this issue, the SDK was updated on 03/17 afternoon, and the doc should now work as expected.
MichelleStuart
I am having the same problem.  Here is a screen recording of what happens when you try to navigate anywhere, "Page Not Found" on repeat.
Also, if I click sign in at the top of developer docs, and select sign in through portal, it signs me into my portal and takes me to my portal home page, if I click Developer Docs, it still says sign in at the top of the page, and becomes an infinite loop of signing into portal, going to docs, having to sign in etc.
JuanMiguelMedinaRodriguez
I can reproduce it too.
Edvinas_S
Yes, entire documentation doesn't work. I reported a service disruption here: Report a service disruption | Esri Support
You can use wayback machine to get to docs while we wait for it to get fixed: MapView | API Reference | ArcGIS Maps SDK for JavaScript 4.29 | ArcGIS Developers
MichelleStuart
Thank you for pointing out the wayback machine tip Edvinas!
BjornSvensson
Yes, we're aware of this and working on a fix.
MichelleStuart
Thanks Bjorn!  That must be stressful and we appreciate all you do to keep the docs site up!
BjornSvensson
Noah-Sager
