ArcGIS JS API 4.20 and Angular 12: build optimization is failing
13458
18
08-19-2021 07:40 AM
NicoleSulzberger
We have migrated our angular application to angular 12. Now the build optimization does not work anymore.
When started up a production build with optimization enabled, we get hundreds of these console logs:
We were able to partly resolve it by enabling optimization in angular.json
"optimization": true,
but setting the environment variable NG_BUILD_MANGLE to false. It's not that nice, but at least it still does part of the optimization.
see also https://indepth.dev/posts/1258/a-gentle-introduction-into-tree-shaking-in-angular-ivy
Are there other developer experiencing this issue? Will Esri support fixing this issue in further releases?
PeteVitt
Thanks Andy, I will look into these
PeteVitt
Hi Andy - I'm using the following to copy the esri library to the assets directory on my website:
angular.json file (within architect-->build)
"assets": [
                "glob": "**/*",
                "input": "node_modules/@arcgis/core/assets",
                "output": "/assets/"
I'm referencing the local build of the library on my website in my map component code file inside the ngOnInit function using: esriConfig.assetsPath = 'assets/';
I've confirmed that the assets folder is copied to my website and contains an esri subdirectory with all the ESRI resources, including  the 'libtess.wasm' file which is throwing a 404 error.
Any other thoughts of what could be causing the problem I'm having?
Thanks
Pete
 to my website
NicoleSulzberger
I had a similar issue, but in my case my webserver IIS did not know the mime type .wasm. I had to configure it.
File name extension: wasm
MimeType: application/wasm
PeteVitt
Thanks Nicole - that did the trick.  Strangely it was working before the angular 12 upgrade without the wasm MIME type in iis
Pete
JeroenBloemscheer
Now that angular 13 is released, can you confirm this is compatible with
ArcGIS JS API 4.20?
AndyGup
Confirmation is in-progress for 4.21 and /next. I'll post any updates to this repo: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli.
PeteVitt
Hi Jeroen -  I haven't had a chance to upgrade yet --  I'll post when I do the upgrade.
Pete
PeteVitt
the upgrade to angular13 went well.  Using arcgis javascript 4.22 -- no problems
RedCanzian
I had a similar issue with the "optimization" param, but more subtle. There were no build or runtime errors, but the map was not working. I didn't want to turn off the optimization, so after hours of troubleshooting, I found out that there's a problem with ESBuild 🫠 (I'm using Angular 17). Details here: https://github.com/Esri/jsapi-resources/tree/main/esm-samples/jsapi-angular-cli#known-issues
Bottom line: Always use the official repo to get started with something consistent!
