I cant seem to load a basic webmap into a bootstrap div.
<div class="row">
<div class="col-xs-12" style="background-color: red">
<div id="viewDiv">
</div>
</div>
</div>
No map, any ideas? Is there some conflict with 4.0 and bootstrap?
Specify a CSS height attribute for the viewDiv container.
Can you post the rest of your code or a sample that is similar?
All I did was add bootstrap/jquery and inclose the view container div.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>Get started with MapView - Create a 2D map</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.0/esri/css/main.css">
<script src="https://js.arcgis.com/4.0/"></script>
<script src="https://code.jquery.com/jquery-2.2.2.min.js"></script>
<link rel="stylesheet" type="text/css" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css">
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/js/bootstrap.min.js"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"dojo/domReady!"
], function(Map, MapView){
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv", // Reference to the scene div created in step 5
map: map, // Reference to the map object created before the scene
zoom: 4, // Sets the zoom level based on level of detail (LOD)
center: [15, 65] // Sets the center point of view in lon/lat
</script>
</head>
<body>
<div class="row">
<div class="col-sm-12">
<div id="viewDiv"></div>
</div>
</div>
</body>
</html>
Kyle,
Not sure why you would want to use bootstrap grid when you only have a one row one column layout but here is your code fixed for that:
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.nopadding {
padding: 0 !important;
margin: 0 !important;
</style>
<script>
require([
"esri/Map",
"dojo/dom-style",
"dojo/domReady!"
], function(Map, MapView, domStyle) {
var map = new Map({
basemap: "streets"
domStyle.set("viewDiv", "height", getPageHeight() + "px");
function getPageHeight() {
var body = document.body,
html = document.documentElement;
var height = Math.max(body.scrollHeight, body.offsetHeight,
html.clientHeight, html.scrollHeight, html.offsetHeight);
return height;
</script>
</head>
<body>
<div class="row nopadding">
<div class="col-md-12 nopadding">
</div>
</div>
</body>
</html>
The 1 row/1 column was just an example. Change it to 2 columns and it performs the same way. Adding a height to the div used for the map container has solved it.
