arcgis 10.2 how to order query results
6714
7
06-23-2015 04:31 PM
davidzornosa
Hi
Is there a way to order the returned results of a query task?
this:
query.where = "COD > 0";
works fine, but this:
query.where = "COD > 0 order by COD";
throws:
dojo.io.script error undefined
Please note that our server has standardized queries enabled and we cannot change that.
Thanks
Tags (1)
RobertScheitlin__GISP
David,
   You can not just add an order by to the where. You need to use the orderByFields property of the Query.
Query | API Reference | ArcGIS API for JavaScript
XanderBakker
Esri Esteemed Contributor
Hi david zornosa ,
Could you move this thread to the ArcGIS API for JavaScript  place. You will get better answer in that space.
See: Moving Content
GeoNet Help is for help on using GeoNet only.
XanderBakker
BTW: this is the page where you can consult the GeoNet Community Structure
David,
XanderBakker
And now something on topic. Maybe this link will help Query | API Reference | ArcGIS API for JavaScript . There is a orderByFields property that you could use (I think).
edit: ...and I should have known that Robert would beat me to it..
OwenEarley
You could use client side sorting for this - see this quick demo I put together: QueryTask - client side sorting
Basically, you just use the array.sort method with an anonymous function:
          results.features.sort(function(a, b) {
              // return  a.attributes.POP2007 - b.attributes.POP2007; // ascending
              return  b.attributes.POP2007 - a.attributes.POP2007; // descending
In your case replace the POP2007 field name with COD to sort the features.
ChrisSmith7
Honored Contributor
Like others mentioned, you could use orderByFields, or client-side sorting. However, I bet it would work if you turned-off standardized queries and used a subquery for the where clause (that contained an ORDER BY). Note that I would NOT recommend doing this!
david zornosa​ Did these replies help you? If so then please make this question as Answered. And if you that that a reply was helpful then click the helpful link on that post.
