ApplyEdits on a TABLE
2598
06-13-2017 03:16 AM
SaraEL_MALKI
Hi guys,
I wanna display a table  (it's the result of a many to many relationship) then be able to updated it (editing the editable inputs),
My first question is will the function of "Attribute table" work for my table?
my second question what's the kind of query to send to the server in order to updated it ? (should be a graphic ) ?
( the image below)
Updates
Thomas Solow‌ Rebecca Strauch, GISP Robert Scheitlin, GISP‌ John Zhang
ArcGIS for Server
RobertScheitlin__GISP
Sara,
   You might have guessed from the lack of response to your two other previous posts on this, there are not many attempting this. What you send to the update method of the rest end point depends on the type of feature the relate points to. If the relate is just a table then the update would be a graphic without any geometry specified.
SaraEL_MALKI
I have used the 'attribute table' widget to display the table, and it worked but when I set the property 'editable' to true, and I start editing nothing is edited and I get an error in the console saying "Can't complete this operation" meanwhile editing works for layers.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>FeatureTable - Custom Menu Items</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<script src="https://js.arcgis.com/3.20/"></script>
<style>
html, body, #map {
width: 100%;
height: 100%;
margin: 0;
padding: 0;
</style>
<script>
require([
"esri/layers/FeatureLayer",
"esri/dijit/FeatureTable",
"esri/geometry/Extent",
"esri/graphicsUtils",
"esri/tasks/query",
"esri/symbols/PictureMarkerSymbol",
"esri/map",
"dojo/dom",
"dojo/parser",
"dojo/ready",
"dojo/on",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer"
], function (
FeatureLayer, FeatureTable, Extent, graphicsUtils, Query, PictureMarkerSymbol, Map,
dom, parser, ready, on, ContentPane, BorderContainer
parser.parse();
ready(function(){
var map = new Map("map",{
basemap: "dark-gray",
center: [-5.80, 35.75],
zoom: 12
//Load a FeatureTable to the application once map loads
map.on("load", loadTable);
function loadTable(){
// editable FeatureLayer
var myFeatureLayer = new FeatureLayer("......./FeatureServer/4", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
visible: true,
// set a selection symbol for the featurelayer
myFeatureLayer.setSelectionSymbol(selectionSymbol);
// listen to featurelayer click event to handle selection
// from layer to the table.
// when user clicks on a feature on the map, the corresponding
// record will be selected in the table.
myFeatureLayer.on("click", function(evt) {
var idProperty = myFeatureLayer.objectIdField,
feature,
featureId,
query;
if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty]) {
feature = evt.graphic,
featureId = feature.attributes[idProperty];
query = new Query();
query.returnGeometry = false;
query.objectIds = [featureId];
query.where = "1=1";
myFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);
// Redlands police vehicle locations layer
// this layer is an editable layer
map.addLayer(myFeatureLayer);
//create new FeatureTable and set its properties
var myFeatureTable = new FeatureTable({
featureLayer : myFeatureLayer,
map : map,
editable: true,
syncSelection: true,
dateOptions: {
datePattern: 'M/d/y',
timeEnabled: true,
timePattern: 'H:mm',
// use fieldInfos object to change field's label (column header),
// change the editability of the field, and to format how field values are displayed
// you will not be able to edit callnumber field in this example.
fieldInfos: [
alias: 'Identifiant',
editable: false //disable editing on this field
alias: "Zone",
format: {
template: "${value} mph" //add mph at the of the value
alias: "le type"
alias: 'Etat abimé'
// add custom menu functions to the 'Options' drop-down Menu
menuFunctions: [
label: "Filter Available Emergency Vehicles",
callback: function(evt){
console.log(" -- evt: ", evt);
// set definition expression on the layer
// show only available emergency vehicles
myFeatureLayer.setDefinitionExpression("type = '240L'");
// call FeatureTable.refresh() method to re-fetch features
// from the layer. Table will only show records that meet
// layer's definition expression creteria.
myFeatureTable.refresh();
label: "Show All Emergency Vehicles",
myFeatureLayer.setDefinitionExpression("1=1");
}, 'myTableNode');
myFeatureTable.startup();
// listen to refresh event
myFeatureTable.on("refresh", function(evt){
console.log("refresh event - ", evt);
</script>
</head>
<body class="claro esri">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
<div id="map"></div>
</div>
<div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%;">
<div id="myTableNode"></div>
</div>
</div>
</body>
</html>
