ApplyEdits failing for updates
1811
07-22-2010 10:07 AM
RaviKonaparthi
Hi All,
I am facing a strange problem while working with feature layers. I am able to POST request for feature layer for adds but when i use applyedits for updates using POST the proxy  file throws an exception.
This feature is working for me till couple of days ago and all of sudden updates using POST is failing and i am using proxy.ashx for posting data.
Can any one help me on this? i am attaching the screen shots of the request from firebug.
Regards,
Ravi.
by Anonymous User
Not applicable
Original User: geodan7
I'm also having a problem applying edits for updates. Were you able to resolve your issue? I'm able to add and delete features, but updates are failing. I tried looking at the FeatureEditResult object...but for updates...it's just 'null'... any ideas?
RaviKonaparthi
This is because of the organizational proxy settings (firewall). We need to bypass the ip from the firewall. Then POST operations will work.
Regards,
Ravi.
by Anonymous User
Not applicable
My issue was much simpler...the setAttributes method was removing my objectID from the feature...just had to make sure I include it.
