Installion problem in JavaScript API 2.6 and 2.7
1001
04-16-2012 04:41 AM
VickyP
Dear All,
I am trying to install JavaScript API locally, it is working from a url for example http://localhost/arcgis_js_api/library/2.7/jsapi/ it allows me to download the file, but when I put it inside a webpage that will display the map, using DOJO library, it is not working properly, it is through a javascript error:- Microsoft JScript runtime error: '3' is null or not an object, here 3 is an array that needs a username, I have gone through the installation steps for JavaScript API and did exactly what they have written. Please help if you know the solution?
