Apply edits
11484
26
10-22-2016 11:14 PM
bharathreddy
hi,
can anyone give an example on how to apply edits while editing two layers in arcgis javasscript
RobertScheitlin__GISP
Bharath,
   What code have you tried? What errors do you get in your browsers web console? Your replies are so vague that it is hard to provide help.
bharathreddy
Here is my code im adding on click both point and line,i am able to add them but unable to apply edits to them
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>LT ext</title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
<style>
html, body
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
.btn
background: #3f3f3f;
color: #fff;
font-family: Tahoma;
font-size: 11px;
height: 18px;
.lbl
color: #000;
font-size: 11px;
font-weight: 200;
#header
border: solid 1px #e4e4e4;
background: #fff;
color: #749749;
-moz-border-radius: 4em;
border-radius: 4em;
font-size: 14px;
padding-left: 20px;
font-weight: 700;
#map
padding: 1px;
-moz-border-radius: 4px;
border-radius: 4px;
#rightPane
border: none;
width: 250px;
height: 95%;
padding-bottom: 10px;
top: 20px;
.templatePicker
border: solid 2px #e4e4e4 !important;
</style>
<script> var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.editing.TemplatePicker-all");
dojo.require("esri.tasks.query");
dojo.require("esri.toolbars.draw");
var map, line, lineGraphic, toolbar, symbol, geomTask;
var landuseLineLayer;
var landusePointLayer;
function init() {
//This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
esri.config.defaults.io.proxyUrl = "/proxy";
esri.config.defaults.io.alwaysUseProxy = false;
//This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new esri.Map("map", {
center: [-83.244, 42.581],
zoom: 15
dojo.connect(map, "onLayersAddResult", initEditing);
queryTask = new esri.tasks.QueryTask("http://localhost:6080/arcgis/rest/services/edit/MapServer/20");
// //initialize query
query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["LTP_ID", "OBJECTID"];
// //create symbol for selected features
symbol = new esri.symbol.SimpleMarkerSymbol();
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
//symbol.setColor(new esri.Color([255, 255, 0, 0.5]));
var labels = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/edit/MapServer");
map.addLayer(labels);
landusePointLayer = new esri.layers.FeatureLayer("http://localhost:6080/arcgis/rest/services/edit/FeatureServer/20", {
mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"]
landuseLineLayer = new esri.layers.FeatureLayer("http://localhost:6080/arcgis/rest/services/edit/FeatureServer/34", {
outFields: ["*"]
map.addLayers([landusePointLayer, landuseLineLayer]);
var ltline = landuseLineLayer;
var ltpole = landuseLineLayer;
dojo.connect(map, "onLoad", function () {
dojo.connect(dijit.byId("map"), "resize", map, map.resize);
var selectedTemplate;
function LTEXT() {
//var l = landuseLineLayer;
var p1 = new esri.geometry.Point(218103.84229999967, 1172648.3827999998, map.spatialReference);
line = new esri.geometry.Polyline();
line.addPath([p1]);
dojo.connect(map, "onClick", addPt);
function addPt(e) {
debugger;
var featureLayers;
var geometryType;
debugger;
// create a new path using the current line endpoint and the click point
//var p2 = esri.geometry.geographicToWebMercator(new esri.geometry.Point(e.mapPoint.x, e.mapPoint.y, map.spatialReference));
//line.addPath([p2]);
var pathCount = line.paths.length;
line.addPath([line.paths[pathCount - 1][line.paths[pathCount - 1].length - 1], [e.mapPoint.x, e.mapPoint.y]]);
lineGraphic = map.graphics.add(new esri.Graphic(line, new esri.symbol.SimpleLineSymbol()));
map.graphics.add(new esri.Graphic(e.mapPoint, new esri.symbol.SimpleMarkerSymbol()));
var k = landuseLineLayer;
var p = landusePointLayer;
saveedits(lineGraphic, landuseLineLayer, landusePointLayer)
//lineGraphic.setGeometry(line);
function saveedits(linegraphic, landuseLineLayer, landusePointLayer) {
debugger;
var graphic;
//graphic.setAttributes(attrs);
var newGraphic = new esri.Graphic(lineGraphic, null);
landuseLineLayer.applyEdits([newGraphic], null, null);
// var newGraphic1 = new esri.Graphic1(e.mapPoint, null,null);
// landusePointLayer.applyEdits([newGraphic1], null,null);
function initEditing(results) {
debugger;
var map = this;
var currentLayer = null;
var layers = dojo.map(results, function (result) {
return result.layer;
var editToolbar = new esri.toolbars.Edit(map);
dojo.connect(editToolbar, "onDeactivate", function (tool, graphic) {
currentLayer.applyEdits(null, [graphic], null);
featureLayers: layers,
dojo.connect(drawToolbar, "onDrawEnd", function (geometry) {
debugger;
drawToolbar.deactivate();
editToolbar.deactivate();
var newAttributes = dojo.mixin({}, selectedTemplate.template.prototype.attributes);
var newGraphic = new esri.Graphic(geometry, null, newAttributes);
selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
function executeQueryTask(sTownID) {
debugger;
query.where = "LTP_ID ='" + sTownID + "'";
//execute query
queryTask.execute(query, showResults);
function showResults(featureSet) {
debugger;
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
console.log(resultFeatures);
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
//graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
if (graphic.geometry.type === 'point') {
debugger;
map.centerAndZoom(graphic.geometry, 0.001);
dojo.ready(init);
</script>
</head>
<body class="claro">
<div style="height: 30px; border: solid 1px; border-color: #e4e4e4; width: 100%;
background: #f0ebff">
Header
</div>
<div style="height: 25px; border: solid 1px; border-color: #e4e4e4; width: 100%;
background: #d2d2d2; text-align: center">
ToolBar
</div>
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="gutters:true, design:'sidebar'"
style="width: 100%; height: 100%;">
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
</div>
<div id="rightPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'">
<span class="lbl">Enter Value :</span>
<input type="text" id="pop" style="width: 150px;" />
<input type="button" value="Zoom" onclick="executeQueryTask(dojo.byId('pop').value);"
class="btn" />
<div id="templatePickerDiv1">
<input type="button" id="templatePickerDiv" value="Start LT Ext" onclick="LTEXT()"
class="btn" />
</div>
</div>
</div>
</body>
</html>
SarojThapa1
Bharath,
Are you running your .html file from a localhost or from a file?The edits are usually not saved if they are just run from a file.What codes have you tried so far? Do you want only attribute editing or full editing (attributes + geometry)?
bharathreddy
I am trying full editng here is my code.i am able to add point and line on click but unable to save them
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
html, body
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
.btn
color: #fff;
font-size: 11px;
height: 18px;
.lbl
color: #000;
font-size: 11px;
font-weight: 200;
#header
background: #fff;
color: #749749;
border-radius: 4em;
font-size: 14px;
padding-left: 20px;
font-weight: 700;
#map
padding: 1px;
border-radius: 4px;
#rightPane
border: none;
width: 250px;
height: 95%;
top: 20px;
.templatePicker
</style>
<script>
function init() {
zoom: 15
symbol.setSize(10);
outFields: ["*"]
outFields: ["*"]
function LTEXT() {
line.addPath([p1]);
function addPt(e) {
debugger;
var featureLayers;
var geometryType;
debugger;
debugger;
var graphic;
debugger;
var map = this;
debugger;
debugger;
//execute query
debugger;
debugger;
dojo.ready(init);
</script>
</head>
Header
</div>
ToolBar
</div>
</div>
class="btn" />
class="btn" />
</div>
</div>
</div>
</body>
</html>
bharathreddy
while applying edits i am getting following error   TypeError: Cannot read property '_getInfo' of undefined
Bharath,
  In your code you use: selectedTemplate.template.prototype.attributes but I never see where you define what selectedTemplate is.
bharathreddy
Robert,
             Selected template is their in the code which i have posted but im not using that part  im tring to apply edits for line feature here is the modified code
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
html, body
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
.btn
color: #fff;
font-size: 11px;
height: 18px;
.lbl
color: #000;
font-size: 11px;
font-weight: 200;
#header
background: #fff;
color: #749749;
border-radius: 4em;
font-size: 14px;
padding-left: 20px;
font-weight: 700;
#map
padding: 1px;
border-radius: 4px;
#rightPane
border: none;
width: 250px;
height: 95%;
top: 20px;
.templatePicker
</style>
<script>
function init() {
zoom: 15
symbol.setSize(10);
outFields: ["*"]
outFields: ["*"]
function LTEXT() {
line.addPath([p1]);
function addPt(e) {
debugger;
var featureLayers;
var geometryType;
debugger;
debugger;
var graphic;
debugger;
//execute query
debugger;
debugger;
dojo.ready(init);
</script>
</head>
Header
</div>
ToolBar
</div>
</div>
class="btn" />
class="btn" />
</div>
</div>
</div>
</body>
</body>
Bharath,
  In your addPt function you have:
Where lineGraphic is a graphic object. Then in your saveedits function you attempt to create a new graphic out of the lineGraphic which is already a Graphic...
            debugger;
            var graphic;
So It should be just:
            debugger;
            landuseLineLayer.applyEdits([linegraphic], null, null);
bharathreddy
I have tried the process which u mentioned but i am getting following error (index):15 Error: Unable to complete operation.(…)
moreover line graphics are disabling while applying edits waiting for ur reply
bharathreddy
Robert,
I am attaching files of graphics which are disappearing while applying edits
