Angular component in Map Popup Content
2074
08-27-2024 12:14 AM
WoraminSat
Hi
Is there any way to insert Angular component into Map Popup Content?
For example ,
const dataPopup = { name : "John Doe" , departmentId : 1 };
const mapPopup = new Popup();
popup.content = "<my-custom-content [propsA]="dataPopup " />";
In React I use to create custom component with Virtual DOM, but I have no idea how to do with Angular Component.
If anyone has an idea to achieve this, please share it with me.
Thanks
Woramin S.
ForrestLin
Convert Angular component to Custom element
https://angular.dev/guide/elements
ForrestLin
ForrestLin
This is how I create CustomContent (and PopupTemplate) using Angular component: PopupComponent.
import { Injector, Renderer2, RendererFactory2, inject } from "@angular/core";
import { NgElement, WithProperties, createCustomElement } from "@angular/elements";
import CustomContent from "@arcgis/core/popup/content/CustomContent";
_renderer2: Renderer2 = inject(RendererFactory2).createRenderer(null, null);
_injector = inject(Injector);
createPopupTemplate(): PopupTemplate {
    const popupTemplate = new PopupTemplate({
      title: this.title,
      outFields: ["*"],
      content: [this.createCustomContent()],
      actions: [],
      fieldInfos: []
    return popupTemplate;
  createCustomContent(): CustomContent {
    const customContent = new CustomContent({
      outFields: ["*"],
      creator: event => {
        this._graphic = event?.graphic;
        const popupEl = this.createPopupElement();
        return popupEl;
    return customContent;
  createPopupElement(): NgElement & WithProperties<PopupComponent> {
    if (!customElements.get('popup')) {
      const popupElement = createCustomElement(PopupComponent, { injector: this._injector });
      customElements.define('popup', popupElement);
    const popupElement: NgElement & WithProperties<PopupComponent> =                 this._renderer2.createElement('popup');
    return popupElement!;
WoraminSat
Sorry for the late response. I have been very busy with my projects.
Anyway, I tried your example and adapt it to my code.
This is how I create from your example
TestPopupComponent (HTML & Typescript)
<p>This is the message from input --- {{message}}</p>
import { Component, Input } from '@angular/core';
@Component({
  selector: 'mea-test-popup-component',
  templateUrl: './test-popup-component.component.html',
  styleUrls: ['./test-popup-component.component.scss']
export class TestPopupComponentComponent {
  @Input() message: string = ''
 MainComponent
 import { Injector, Renderer2, RendererFactory2, inject } from '@angular/core';
import { NgElement, WithProperties, createCustomElement } from '@angular/elements';
import CustomContent from '@arcgis/core/popup/content/CustomContent';
import { TestPopupComponent } from './test-popup-component/test-popup.component';
//From mapView on click
displayPopup(mapPoint: Point){
        if (!customElements.get('mea-test-popup-component')) {
            const popupElement = createCustomElement(TestPopupComponent, { injector: this._injector });
            customElements.define('mea-test-popup-component', popupElement);
        const testComponent: NgElement & WithProperties<TestPopupComponent> = this._renderer2.createElement('mea-test-popup-component');
        testComponent.message = 'Hello, world!';
        this.mapView.openPopup({
            content: testComponent,
The Result
Thank you very much for your help!
ForrestLin
@WoraminSat
Great!
