Add feature layer to map component using angular
2728
04-15-2025 01:33 PM
PeteVitt
Hi - I'm working with Javascript maps SDK 4.32 and am attempting to add a feature layer to a map component.  I'm basing my effort on the map component angular sample on github (https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-components/samples/angular)  and this post about adding a feature layer to a map component (https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/map-component-api/td-p/1418711)
Below is the code I'm using. I'm getting an error 'addLayer does not exist on type element'
html:
<arcgis-map item-id="d5dda743788a4b0688fe48f43ae7beb9" (arcgisViewReadyChange)="arcgisViewReadyChange($event)"></arcgis-map>
component:
import { Component, CUSTOM_ELEMENTS_SCHEMA } from '@angular/core';
import "@arcgis/map-components/components/arcgis-map";
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
@Component({
  selector: 'app-rd-map2',
  imports: [],
  templateUrl: './rd-map2.component.html',
  styleUrl: './rd-map2.component.css',
  schemas: [CUSTOM_ELEMENTS_SCHEMA]
export class RdMap2Component {
  arcgisMap = document.querySelector("arcgis-map");
  featureLayer = new FeatureLayer({
    url:
  ngOnInit() {
    var a = this;
    a.arcgisMap.addEventListener("arcgisViewReadyChange", () => {
      a.arcgisMap.addLayer(this.featureLayer);//==> error occurs here addLayer does not exist on type element
any ideas how to get a reference to the map component so the feature layer can be added?
Thanks
Pete
ReneRubalcava
Esri Frequent Contributor
Here is a sample Angular app that adds a layer and more. You don't instantiate components, just declare them via html elements.
https://github.com/odoe/map-components-angular/blob/main/src/app/components/map/map.component.ts
PeteVitt
I've made a little progress.  I can see the arcgis-map component properties from the event.target (see attached console screen shot)
  arcgisViewReadyChange(event: any) {
    var map = event.target;
    console.log(map);
Can I type my map variable to ArcgisMap from this import statement?
import { ArcgisMap } from "@arcgis/map-components/dist/components/arcgis-map";
I've been trying to do that like this:
  var map:ArcgisMap = new ArcgisMap();
  map = event.target;
but I'm getting a kind of ugly typescript an error: TS2304: cannot find name 'WeakRef'
ReneRubalcava
PeteVitt
Thanks Rene - got the feature layer added.
Pete
PeteVitt
Got the  error: TS2304: cannot find name 'WeakRef' solved by adding adding ESNext to tsconfig.json
 "lib": [
      "es2018",
      "ESNext",
      "dom"
new error is
TS2339: Property 'messages' does not exist on type 'ArcgisBasemapGallery'
