esri geometry coordinateFormatter toLatitudeLongitude using wrong minute format
1493
5
04-03-2025 02:33 PM
SebastianKrings
We are using the toLatitudeLongitude method of the coordinateFormatter to get a string representation of a given point object.
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-coordinateFormatter.html...
Unfortunately, for the cases where the decimalPlaces are set to 0 it adds a leading zero infront of the minute-value leading to a three-digit-value. Thats obviously wrong since minutes only range til 60, so any leading hundet-zero is simply wrong here.
We were pointed on that by some technical experts which are working with coordinates every day.
I did some research and only can find samples and references without a leading hundred-zero.
Can anyone explain me, why esri is doing that? Is there may a function to correct the string?
JonathanDawe_BAS
Hi Sebastian, I raised this issue very recently! it was confirmed as a bug: BUG-000172707 - The ArcGIS Maps SDK for JavaScript coordinateFormatter function converts points incorrectly when the toLatitudeLongitude method has the decimalPlaces parameter set to zero
JonathanDawe_BAS
SebastianKrings
good to know
the bug page doesnt bring much info about details
https://support.esri.com/de-de/bug/the-arcgis-maps-sdk-for-javascript-coordinateformatter-bug-000172...
one should also note, that the wrong output is also part of the documentation which means that the current implementation isnt just buggy but wrong by design.
@JonathanDawe_BAS : can we ensure, that the wrong hundred-zero is exactly what will be fixed by this bug? if so, we can await the fix. If this could not be ensured we would first go with a workaround.
JonathanDawe_BAS
I've actually steered away from using the coordinate.formatter for formatting from a point to a string. I personally only use it for converting the other way from a string to a point.
The rationale was that we wanted a bit more control over the formatting - For example presenting DDM as 54°16.544' S, 36°26.348' W instead of 54 16.544S 36 26.348W.
export type DisplayFormat = 'DD' | 'DMS' | 'DDM';
export const BLANK_COORDINATES = {
  DD: '--.-° N, --.-° E',
  DMS: '--°--\'--\" N, --°--\'--\" E',
  DDM: "--°--.--' N, --°--.--' E",
} as const;
// Utility functions for coordinate conversions
export function decimalToDMS(degree: number, isLat: boolean) {
  const absolute = Math.abs(degree);
  const degrees = Math.floor(absolute);
  const minutesNotTruncated = (absolute - degrees) * 60;
  const minutes = Math.floor(minutesNotTruncated);
  const seconds = ((minutesNotTruncated - minutes) * 60).toFixed(2);
  const direction = isLat ? (degree >= 0 ? 'N' : 'S') : degree >= 0 ? 'E' : 'W';
  return `${degrees}°${minutes}'${seconds}" ${direction}`;
export function decimalToDDM(degree: number, isLat: boolean) {
  const minutes = ((absolute - degrees) * 60).toFixed(3);
  return `${degrees}°${minutes}' ${direction}`;
export function formatLatitude(latitude: number) {
  const direction = latitude >= 0 ? 'N' : 'S';
  const absoluteValue = Math.abs(latitude).toFixed(2);
  return `${absoluteValue}° ${direction}`;
export function formatLongitude(longitude: number) {
  const direction = longitude >= 0 ? 'E' : 'W';
  const absoluteValue = Math.abs(longitude).toFixed(2);
export function formatCoordinate(
  lat: number | nullish,
  lon: number | nullish,
  format: DisplayFormat,
  displayPlaceholder: boolean = false,
  if (!isDefined(lat) || !isDefined(lon))
    return displayPlaceholder ? BLANK_COORDINATES[format] : null;
  switch (format) {
    case 'DD':
      return `${formatLatitude(lat)}, ${formatLongitude(lon)}`;
    case 'DMS':
      return `${decimalToDMS(lat, true)}, ${decimalToDMS(lon, false)}`;
    case 'DDM':
      return `${decimalToDDM(lat, true)}, ${decimalToDDM(lon, false)}`;
    default:
      return null;
SebastianKrings
this is awesome. Grate you share your code here.
SebastianKrings
This is my workaround to cut out the zeros until the fix is released:
     * This is a Bugfix of Esri coordinateFormatter.toLatitudeLongitude
     * The Bug is already tracked and in product plan.
     * Which means it may be fixed in the next two releases of ArcGIS.
     * Bug link:
     * https://support.esri.com/en-us/bug/the-arcgis-maps-sdk-for-javascript-coordinateformatter-bug-000172707
     * Nevertheless this method fixes the wrong output as workaround.
     * The problem is, that the minutes are printed as three-digit with leading zeros
     *  although minutes only reach to max. 60.
     * Within this methode the leading hundredth-zero is cut out while a possible tenth-zero is kept.
     * The issue is known for formats 'ddm' and 'dms'.
     * If the given format is anything else, the original coordinates are returned.
     * For both ddm and dms the leading hunderdth-zeros can be found by the hemisphere characters.
     * The fix applies for precision = 0.
     * DDM sample: 55 057N 003 010W
     * DMS sample: 55 56 039N 003 09 043W
     * For latitude we determine the index of the N- or S-character.
     * For longitude we determine the index of the O- or W-character.
     * The leading hundredth-zero is located at index - 3 for both lat- and lon-index.
     *  coordinates to be fixed
     *  format of the coordinates
     * @returns a fixed version of the coordinates if format is of ddm or dms, otherwise the original coordinates are returned.
    private fixBuggyMinuteCoordinateFormat(coordinates: string, format: string): string {
        // only process for formats ddm and dms
        if (format === 'ddm' || format === 'dms') {
            const regex_lat = /[NS]/;
            const regex_lon = /[EW]/;
            const match_lat = regex_lat.exec(coordinates);
            const match_lon = regex_lon.exec(coordinates);
            // only process if string contains N or S
            if (match_lat && match_lon) {
                const lat_i = match_lat.index - 3;
                const lon_i = match_lon.index - 3;
                // only process if there is a 0 at both indices
                if (coordinates.charAt(lat_i) === '0' && coordinates.charAt(lon_i) === '0') {
                    //remove the longitudes zero first
                    coordinates = coordinates.slice(0, lon_i) + coordinates.slice(lon_i + 1);
                    //remove the latitudes zero second
                    coordinates = coordinates.slice(0, lat_i) + coordinates.slice(lat_i + 1);
        return coordinates;
