4.24 Geometry($feature).z
1000
10-23-2022 02:07 AM
Wade
The current version doesn't seem to work?
sceneView.on('layerview-create', function (event) {
            const mLayer = webScene.allLayers.filter((elem) => {
                return elem.title === "TEST LAYER";
            }).items[0];
            const currentElevationInfo = {
                mode: "absolute-height",
                offset: 0,
                featureExpressionInfo: {
                    expression: "Geometry($feature).z * 100"
                unit: "meters"
            mLayer.elevationInfo = currentElevationInfo;
by Anonymous User
Not applicable
Hi @Wade
Thanks for reaching out! Just from looking at the code I cannot find any mistakes, and also the sample we provide still seems to work.
So could you maybe provide us with a working codepen example where the problem is visible? Maybe the issue here is not the Arcade expression but something else, so I would be happy to help you debug. It could be that the layer does not have any z-values stored for example.
Best,
Daniel
Wade
Hi @Anonymous User
Thank you, I found the possible reason, it should be the reason for publishing the service, 3d to multipatch.
