4.19 oAuth repeated log in.
991
05-27-2021 10:08 AM
MikeGarcia
I am not sure if I am missing something new in the 4.19 API.
In trying to reuse my 4.18 oAuth code in a new 4.19 app, I have found replacing the reference from 4.18 to 4.19 has cause some unexpected results.
Using 4.19, I am continually asked to sign-in.
Once logged-in everything works, but it is inefficient and super annoying to have to log-in after every reload.
I have an Enterprise 10.8.1 Portal, using secure feature services in the app.
SSO is working for the portal, and all of my 4.18, and 3.25 apps.
// Set Portal URL in esriConfig.
esriConfig.portalUrl = "https://MYENTERPRISE/portal";
// Set AppId and enable OAuth
var oAuthInfo = new OAuthInfo({
  appId: "myRegisteredAppId",
  popup: false,
esriId.registerOAuthInfos([oAuthInfo]);
// Intialize a portal instance and load it
var portal = new Portal();
