4.0 Beta 2 Home Button strange behavior
9253
20
11-25-2015 08:56 AM
DavidChrest
The Home widget was added in 4.0 Beta 2. It's dead simple to add and the provided example code is a simple, minimal page of just a Scene and the Home Button. However, when I add the Home Button widget to my page which utilizes some other widgets (not sure if this has anything to do with it) my map view literally pans down and zooms in a bit on a nonstop repeating loop right on startup. Has anybody else seen this? Looks like some kind of Beta 2 bug.
David
RickeyFight
David,
I copied your code into jsbin and added Yue Wu css and it worked.
JS Bin - Collaborative JavaScript Debugging
MikeCrook
I'm currently using the Home button on JS API 4.0 Beta2. I don't see any behavior like that. It appears to be working as intended.  However you said that your Home widget is utilized with other widgets and maybe that the problem.  I am using a few other controls, like basemap toggle, search widget and a few others and the home button still seems fine.  If you provide a snippet, maybe we can spot something wierd.
DavidChrest
Thanks much Mike. My page has other controls too like you: basemap toggle, search widget, and others. My Home widget is not really "utilized" with other widgets. Below is my entire page. All I did was add in the CSS, the "esri/widgets/Home," the "Home" in my variables list, the "homeBtn" setup snippet right after the map setup at the top, and then the <div at the bottom.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Day 1 3D</title>
  <style>
  html,
  body {
  padding: 0;
  margin: 0;
  #searchDiv {
  position: absolute;
  z-index: 20;
  top: 15px;
  left: 65px;
  #buttonsDiv {
  position: absolute;
  top: 12px;
  right: 12px;
  padding: 12px;
  background-color: rgba(200, 200, 200, 0.5);
  border: 1px solid black;
  #indicatorSpan {
  display: inline-block;
  vertical-align: middle;
  width: 30px;
  height: 30px;
  background-color: rgba(100, 100, 100, 0.8);
  border: 2px solid #ccc;
  #environmentDiv {
  position: absolute;
  top: 12px;
  right: 140px;
  padding: 2px;
  background-color: rgba(0, 0, 0, 0.5);
  color: white;
  #BasemapToggleDiv {
  position: absolute;
  top: 78px;
  right: 12px;
  #homediv {
  position: absolute;
  top: 120px;
  left: 10px;
  z-index: 50;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta2/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta2/esri/css/main.css">
  <script src="https://js.arcgis.com/4.0beta2/"></script>
  <script>
  var map, view;
  require([
  "esri/Map",
  "esri/Color",
  "esri/widgets/Home",
  "esri/layers/GraphicsLayer",
  "esri/Graphic",
  "esri/geometry/Point",
  "esri/geometry/Polyline",
  "esri/geometry/Polygon",
  "esri/symbols/SimpleMarkerSymbol",
  "esri/symbols/SimpleLineSymbol",
  "esri/symbols/SimpleFillSymbol",
  "esri/PopupTemplate",
  "esri/views/SceneView",
  "esri/widgets/BasemapToggle",
  "esri/widgets/Search",
  "esri/layers/FeatureLayer",
  "esri/symbols/PolygonSymbol3D",
  "esri/symbols/ExtrudeSymbol3DLayer",
  "esri/renderers/SimpleRenderer",
  "esri/symbols/PointSymbol3D",
  "esri/symbols/ObjectSymbol3DLayer",
  "dojo/on",
  "dojo/dom",
  "dojo/domReady!"
  function (Map, Color, Home, GraphicsLayer, Graphic, Point, Polyline, Polygon, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, PopupTemplate, SceneView, BasemapToggle, Search, FeatureLayer, PolygonSymbol3D, ExtrudeSymbol3DLayer, SimpleRenderer, PointSymbol3D, ObjectSymbol3DLayer, on, dom) {
  var objectSymbol, objectSymbolRenderer, day1Activities;
  //Create Map
  map = new Map({
  basemap: "topo"
  //Create SceneView and set viewpoint
  view = new SceneView({
  container: "viewDiv",
  map: map,
  scale: 15000,
  center: [-77.009, 38.889]
  var homeBtn = new Home({
  view: view
  }, "homediv");
  homeBtn.startup();
  //<<<ENVIRONMENT - SHADOWS>>>
  //Set the environment in SceneView
  view.environment = {
  lighting: {
  directShadows: true,
  date: new Date("Sun Mar 15 2015 09:00:00 GMT-0500 (EST)")
  //Register the events to controls
  on(dom.byId("timeOfDaySelect"), "change", updateTimeOfDay);
  on(dom.byId("directShadowsInput"), "change", updateDirectShadows);
  //Create the event's callback functions
  function updateTimeOfDay(ev) {
  var select = ev.target;
  var date = select.options[select.selectedIndex].value;
  view.environment.lighting.date = new Date(date);
  function updateDirectShadows(ev) {
  view.environment.lighting.directShadows = !!ev.target.checked;
  //<<<DAY 1 ACTIVITIES>>>
  //Create objectSymbol for Day 1 Activities and add to renderer
  objectSymbol = new PointSymbol3D({
  symbolLayers: [new ObjectSymbol3DLayer({
  width: 15,
  height: 15,
  anchor: "bottom",
  resource: {
  primitive: "sphere"
  material: {
  color: "purple"
  objectSymbolRenderer = new SimpleRenderer({
  symbol: objectSymbol
  //Create the Day 1 Activities PopupTemplate
  var template = new PopupTemplate({
  title: "D.C. Day 1 GPS Readings", //description is the text in the popup. {fieldName} can be used to reference the value of the selected feature
  content: "<b> Date: {Day1Date} </b>" +
  "<br><b>Time:</b> {TimeofDay}" +
  "<br><b>Latitude:</b> {Latitude}" +
  "<br><b>Longitude:</b> {Longitude}"
  //Request Day 1 Activities featureLayer and overwrite renderer
  day1Activities = new FeatureLayer({
  url: "http://sushi:6080/arcgis/rest/services/DavidC/MovesDCDay1/MapServer/2",
  outFields: ["*"],
  popupTemplate: template,
  renderer: objectSymbolRenderer,
  //Ensure that all features are shown at all scales
  maxScale: 0,
  minScale: 0
  map.add(day1Activities);
  day1Activities.renderer = objectSymbolRenderer;
  //<<<STARBUCKS>>>
  //Create objectSymbol for Starbucks and add to renderer
  objectSymbolSB = new PointSymbol3D({
  width: 15,
  height: 50,
  anchor: "bottom",
  resource: {
  primitive: "cylinder"
  material: {
  color: ([115, 0, 0, 0.5])
  objectSymbolSBRenderer = new SimpleRenderer({
  symbol: objectSymbolSB
  //Create the Starbucks PopupTemplate
  var templateSB = new PopupTemplate({
  title: "Starbucks  {Name}", //description is the text in the popup. {fieldName} can be used to reference the value of the selected feature
  content: "<b>Store Number: {Store_Number}</b>" +
  "<br><b>Name:</b> {Name}" +
  "<br><b>Ownership:</b> {Ownership_Type}" +
  "<br><b>Products:</b> {Features_Products}" +
  "<br><b>Services:</b> {Features_Service}" +
  "<br><b>Phone:</b> {Phone}" +
  "<br><b>Address:</b> {Street_Address}" +
  "<br><b>City:</b> {City}" +
  "<br><b>State:</b> {State}" +
  "<br><b>Zip:</b> {Zip}" +
  //Request Starbucks featureLayer and overwrite renderer
  starbucks = new FeatureLayer({
  url: "http://sushi:6080/arcgis/rest/services/DavidC/MovesDCSBFF/MapServer/0",
  outFields: ["*"],
  popupTemplate: templateSB,
  renderer: objectSymbolSBRenderer,
  maxScale: 0,
  minScale: 0
  map.add(starbucks);
  starbucks.renderer = objectSymbolSBRenderer;
  //<<<FAST FOOD>>>
  objectSymbolFF = new PointSymbol3D({
  width: 15,
  height: 50,
  anchor: "bottom",
  resource: {
  primitive: "diamond"
  material: {
  color: ([0, 0, 254, 0.5])
  objectSymbolFFRenderer = new SimpleRenderer({
  symbol: objectSymbolFF
  //Create the Fast Food PopupTemplate
  var templateFF = new PopupTemplate({
  title: "Fast Food: {CONAME}", //description is the text in the popup. {fieldName} can be used to reference the value of the selected feature
  content: "<b>Location: {ADDR}</b>" +
  "<br><b>City:</b> {CITY}" +
  "<br><b>State:</b> {STATE}" +
  "<br><b>Zip:</b> {ZIP}" +
  "<br><b>Phone:</b> {PHONE}" +
  "<br><b>NAICS Code:</b> {NAICS}" +
  "<br><b>SIC Code:</b> {SIC}" +
  "<br><b>Year Started:</b> {YRSTARTED}" +
  //Request Fast Food featureLayer and overwrite renderer
  fastfood = new FeatureLayer({
  url: "http://sushi:6080/arcgis/rest/services/DavidC/MovesDCSBFF/MapServer/1",
  outFields: ["*"],
  popupTemplate: templateFF,
  renderer: objectSymbolFFRenderer,
  maxScale: 0,
  minScale: 0
  map.add(fastfood);
  fastfood.renderer = objectSymbolFFRenderer;
  //Create Buildings featureLayer and add to the map
  var buildings3D = new FeatureLayer({
  url: "http://sushi:6080/arcgis/rest/services/DavidC/MovesDCTransit/MapServer/4"
  map.add(buildings3D);
  //Create the Renderer for the buildings,
  var extrudePolygonRenderer = new SimpleRenderer({
  symbol: new PolygonSymbol3D({
  symbolLayers: [new ExtrudeSymbol3DLayer()]
  visualVariables: [{
  type: "sizeInfo",
  field: "Stories",
  minSize: 30,
  maxSize: 30,
  minDataValue: 8,
  maxDataValue: 8
  type: "colorInfo",
  colors: [
  new Color([190, 210, 255, 0.75])
  buildings3D.renderer = extrudePolygonRenderer;
  //Search Widget
  var searchWidget = new Search({
  view: view
  }, "searchDiv");
  searchWidget.startup();
  //<<<EASY NAVIGATION>>>
  //Register events to control
  var rotateAntiClockwiseSpan = dom.byId("rotateAntiClockwiseSpan");
  var rotateClockwiseSpan = dom.byId("rotateClockwiseSpan");
  var indicatorSpan = dom.byId("indicatorSpan");
  on(rotateClockwiseSpan, "click", function () {
  rotateView(1);
  on(rotateAntiClockwiseSpan, "click", function () {
  rotateView(-1);
  on(indicatorSpan, "click", tiltView);
  //Watch the change on view.camera
  view.watch("camera", updateIndicator);
  function rotateView(direction) {
  var heading = view.camera.heading;
  // Set the heading of the view to the closest multiple of 90 degrees,
  // depending on the direction of rotation
  if (direction > 0) {
  heading = Math.floor((heading + 1e-3) / 90) * 90 + 90;
  } else {
  heading = Math.ceil((heading - 1e-3) / 90) * 90 - 90;
  view.animateTo({
  heading: heading
  function tiltView() {
  // Get the camera tilt and add a small number for numerical inaccuracies
  var tilt = view.camera.tilt + 1e-3;
  // Switch between 3 levels of tilt
  if (tilt >= 80) {
  tilt = 0;
  } else if (tilt >= 40) {
  tilt = 80;
  } else {
  tilt = 40;
  view.animateTo({
  tilt: tilt
  function updateIndicator(camera) {
  var tilt = camera.tilt;
  var heading = camera.heading;
  // Update the indicator to reflect the current tilt/heading using
  // css transforms.
  var transform = "rotateX(" + 0.8 * tilt +
  "deg) rotateY(0) rotateZ(" + -heading + "deg)";
  indicatorSpan.style["transform"] = transform;
  indicatorSpan.style["-webkit-transform"] = transform; //Solution for Safari
  //^^^EASY NAVIGATION^^^
  //BASEMAP TOGGLE
  var toggle = new BasemapToggle({
  map: map,
  basemap: "hybrid"
  }, "BasemapToggleDiv");
  toggle.startup();
  //<<<GRAPHICS>>>
  graphicsLayer = new GraphicsLayer();
  map.add(graphicsLayer);
  //Add a 3D point graphic
  var point = new Point({
  x: -77.011,
  y: 38.89686,
  z: 650
  markerSymbol = new SimpleMarkerSymbol({
  color: [69, 150, 255],
  outline: new SimpleLineSymbol({
  color: [255, 0, 0],
  width: 2
  pointGraphic = new Graphic({
  geometry: point,
  symbol: markerSymbol
  graphicsLayer.add(pointGraphic);
  //Add a 3D polyline graphic
  var polyline = new Polyline([
  [-77.011, 38.89686, 0],
  [-77.011, 38.89686, 640]
  lineSymbol = new SimpleLineSymbol({
  width: 4
  polylineGraphic = new Graphic({
  geometry: polyline,
  symbol: lineSymbol
  graphicsLayer.add(polylineGraphic);
  //Add a 3D polygon graphic
  //Ploygon Coordinates taken from digitized KML in Google Earth
  var polygon = new Polygon([
  [-77.01096035528856, 38.8967466432082, 400],
  [-77.01092530398697, 38.89665268015742, 400],
  [-77.0103007644429, 38.89665637370967, 400],
  [-77.01029444259881, 38.89689790704291, 400],
  [-77.0102010903575, 38.89690267859739, 400],
  [-77.01020040140389, 38.8972096365415, 400],
  [-77.01157574798415, 38.89720378112004, 400],
  [-77.01147251335793, 38.89690596573629, 400],
  [-77.01139745184112, 38.89691800587753, 400],
  [-77.01130350043968, 38.89665972200029, 400],
  //fillSymbol does not seem to work unless polygon covers a very large area
  fillSymbol = new SimpleFillSymbol({
  color: [227, 139, 79],
  color: [255, 0, 0, 0.5],
  width: 10
  polygonGraphic = new Graphic({
  geometry: polygon,
  symbol: fillSymbol
  graphicsLayer.add(polygonGraphic);
  //^^^GRAPHICS^^^
  </script>
</head>
<body>
  <div id="searchDiv"></div>
  <div id="viewDiv">
    <div id="homediv"></div>
  </div>
  <div id="BasemapToggleDiv"></div>
  <div id="buttonsDiv">
  <button id="rotateAntiClockwiseSpan" title="Rotate 90°">↻</button>
  <button id="indicatorSpan"></button>
  <button id="rotateClockwiseSpan" title="Rotate 90°">↺</button>
  </div>
  <div id="environmentDiv">
  <table>
  <tr>
  <td>Time of day:</td>
  <td>
  <select id="timeOfDaySelect">
  <option value="Sun Mar 15 2015 09:00:00 GMT-0500 (EST)">Morning</option>
  <option value="Sun Mar 15 2015 12:00:00 GMT-0500 (EST)">Noon</option>
  <option value="Sun Mar 15 2015 16:00:00 GMT-0500 (EST)">Afternoon</option>
  <option value="Sun Mar 15 2015 18:00:00 GMT-0500 (EST)">Evening</option>
  </select>
  </td>
  </tr>
  <tr>
  <td>Direct shadows:</td>
  <td>
  <input id="directShadowsInput" type="checkbox" checked="yes">
  </td>
  </tr>
  </table>
  </div>
</body>
</html>
MikeCrook
the main difference between our code is.
YOUR USING THE SCENEVIEW:
  map: map,
  scale: 15000,
AND I'm using the MapView. Perhaps that's where the issue is...
MikeCrook
and maybe your need to define extext in your view?
RickeyFight
Look at this example: ArcGIS API for JavaScript Sandbox
MikeCrook
oh, so maybe its an issue using the 3D view and the home button... For the home button with 2D seems to work properly...
DavidChrest
Esri's example uses Home Button on a 3D view. See my links below.
DavidChrest
The live example code (https://developers.arcgis.com/javascript/beta/sample-code/widgets-home/live/index.html) as well as the "Explore in Sandbox" page (https://developers.arcgis.com/javascript/beta/sample-code/sandbox/sandbox.html?sample=widgets-home) uses SceneView. I even copied over the same SceneView code and have the same view of the globe but that just pans down and zooms in repeated loop. Below is Esri's simple sample that works. I even copied it to an html file on my PC, opened it and it works fine. But when I insert required Home Button code into my page, I get this very strange behavior. Something in my code is really clashing with that new Home Button.
<!DOCTYPE HTML>
<html>
<head>
  <title>Home button - 4.0beta2</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
    #homediv {
      position: absolute;
      top: 120px;
      left: 10px;
      z-index: 50;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
    ], function(
      Map, SceneView, Home
      var map = new Map({
        basemap: "streets"
      var view = new SceneView({
        map: map,
        center: [-56.049, 38.485, 78],
        zoom: 3
        view: view
      }, "homediv");
      homeBtn.startup();
  </script>
</head>
<body>
  <div id="viewDiv">
  </div>
</body>
</html>
RickeyFight
David,
Does your console.log give any errors?
